程序写不到片子里是怎摸回事! 求教!
程序写不到片子里是怎摸回事! 求教!
我是新手,好容易调通了一个程序,却写不到芯片里,总是出现如下报警:
load failed. a section of your program falls into a memory region
that is not writable.check your linker configuration an /memory map.
我的连接是没有问题的, memory map 可能也没问题!下面是相关的文件:
请高手给我指点指点,我卡在这里无法继续进行了!(还有一个问题就是我要写的芯片是别人写过程序的片子,不知道和这个有没有关系,如果有关系,请告诉我我怎么才能写进新程序!)
先谢谢大家!
/* Code Composer Studio supports five reserved GEL functions that */
/* automatically get executed if they are defined. They are: */
/* StartUp() - Executed whenever CCS is invoked */
/* OnReset() - Executed after Debug->Reset CPU */
/* OnRestart() - Executed after Debug->Restart */
/* OnPreFileLoaded() - Executed before File->Load Program */
/* OnFileLoaded() - Executed after File->Load Program */
StartUp()
/* Initialize F2407 memory map */
F2407_Memory_Map();
/* uncomment the function(s) you want Code Composer Studio to execute
OnReset(int nErrorCode)
OnRestart(int nErrorCode)
OnPreFileLoaded()
OnFileLoaded(int nErrorCode, int bSymbolsOnly)
menuitem "Initialize Memory Map";
/*----------------------- F2407 Memory Map -------------------------*/
/* The entire LF2407 address space (program, data, IO) is mapped */
/* as RAM with two exceptions. The on-chip flash is mapped as */
/* ROM and the following illegal/reserved sections are not */
/* mapped: */
/* Illegal/Rsvd Program Illegal/Rsvd Data Illegal/Rsvd IO */
/* None 0x0080 - 0x01ff None */
/* 0x0400 - 0x07ff */
/* 0x1000 - 0x6fff */
hotmenu F2407_Memory_Map()
int SCSR2 =*0x7019; /* System Control and Status Register 2 */
GEL_MapReset();
GEL_MapOn();
/* Check MPNMC value (SCSR2 bit 2) to determine map setting. */
if(SCSR2 & 4)
GEL_MapAdd(0x0000,0,0x8000,1,1); /* Ext prog memory */
else
GEL_MapAdd(0x0000,0,0x8000,1,0); /* On-chip flash memory */
/* Program Memory Maps */
GEL_MapAdd(0x8000,0,0x0800,1,1); /* SARAM */
GEL_MapAdd(0x8800,0,0x7800,1,1); /* External RAM */
/* Data Memory Maps */
GEL_MapAdd(0x0000,1,0x0060,1,1); /* Mem mapped regs */
GEL_MapAdd(0x0060,1,0x0020,1,1); /* DARAM B2 */
GEL_MapAdd(0x0200,1,0x0200,1,1); /* DARAM B0 & B1 */
GEL_MapAdd(0x0800,1,0x0800,1,1); /* SARAM */
GEL_MapAdd(0x7000,1,0x1000,1,1); /* Peripherals */
GEL_MapAdd(0x8000,1,0x8000,1,1); /* External RAM */
/* I/O Memory Maps */
GEL_MapAdd(0x0000,2,0x10000,1,1);
menuitem "Watchdog";
hotmenu Disable_WD()
/* Enable WD override */
*0x7029 = *0x7029 | 0x0068;
*0x7025 = 0x0055;
*0x7025 = 0x00AA;
"vectors.asm"
.title "vectors.asm"
.ref _c_int0,_nothing
.sect ".vectors"
reset: B _c_int0
int1: b _nothing
int2: b _nothing
int3: b _nothing
int4: b _nothing
int5: b _nothing
int6: b _nothing
"roam.cmd"
-stack 40
MEMORY
PAGE 0:
VECS rigin=0x0000,length=0x0040
PVECS : origin = 0x0040 ,length = 0x0070
PROG : origin=0x00b0,length=0x7f50
PAGE 1:
MMRSrigin = 0x0000, length = 0x005f
B0 : origin=0x0200,length=0x0050
B1 : origin = 0x0300 , length = 100h /* DARAM B1 块 */
B2 : origin=0x0060,length=0x0020
SARAM : origin=0x0800,length=0x0700
EXT : origin=0x8000,length=0x8000
SECTIONS
.reset :{} >VECS PAGE 0
.vectors : {}>VECS PAGE 0
.pvecs:{} >VECS PAGE 0
.text : {} >ROG PAGE 0
.cinit :{} >ROG PAGE 0
.const : {} > SARAM PAGE 1
.bss : {} > SARAM PAGE 1
.stack : {} > B1 PAGE 1
"wgfiotest.c"
#include "regs.h"
initial()
asm(" setc SXM");
asm(" clrc OVM");
asm(" clrc CNF");
asm(" setc INTM");
*SCSR1 = 0x81FE;
*WDCR = 0x0e8;
*IMR = 0x0000;
*IFR = 0x0FFFF;
*MCRA = *MCRA & 0x0FF;
*PBDATDIR = * PBDATDIR |0x0FF00;
*MCRC = *MCRC & 0x0FBFF;
*PBDATDIR = *PBDATDIR & 0x0FF00;
*PFDATDIR = *PBDATDIR | 0x0404;
*PFDATDIR = *PFDATDIR & 0x0FFFB;
main()
{ int led;
int i,k;
initial();
while(1)
for(led = 0x0080,i = 0;i < 8;led = led >>1,i++)
*PBDATDIR = * PBDATDIR & 0x0FF00;
*PBDATDIR = *PBDATDIR | led;
for(k = 0;k<0x0fff;k++)
k = k;
void interrupt nothing()
return;
/* regs.H v3.07 */
/* Copyright (c) 1993-2003 Texas Instruments Incorporated */
volatile unsigned int *SCSR1 = (volatile unsigned int *) 0x7018;
volatile unsigned int *WDCR = (volatile unsigned int *) 0x7029;
volatile unsigned int *IMR = (volatile unsigned int *) 0x0004;
volatile unsigned int *IFR = (volatile unsigned int *) 0x0006;
volatile unsigned int *MCRA = (volatile unsigned int *) 0x7090;
volatile unsigned int *MCRC = (volatile unsigned int *) 0x7094;
volatile unsigned int *PBDATDIR = (volatile unsigned int *) 0x7098;
volatile unsigned int *PFDATDIR = (volatile unsigned int *) 0x7096;
