“ testbench也是.vhd格式吗?或者说怎么新建testbench文件啊? ” 是的,就是,这个和一般的vhdl有一点区别,如 VHDL 示例 library IEEE; use IEEE.std_logic_1164.all; entity testbench is end entity testbench; architecture test_reg of testbench is component shift_reg is port ( clock : in std_logic; reset : in std_logic; load : in std_logic; sel : in std_logic_vector(1 downto 0); data : in std_logic_vector(4 downto 0); shiftreg : out std_logic_vector(4 downto 0)); end component; signal clock, reset, load: std_logic; signal shiftreg, data: std_logic_vector(4 downto 0); signal sel: std_logic_vector(1 downto 0); constant ClockPeriod : TIME := 50 ns; begin UUT : shift_reg port map (clock => clock, reset => reset, load => load, data => data, shiftreg => shiftreg); process begin clock <= not clock after (ClockPeriod / 2); end process; process begin reset <= ’1’; data <= "00000"; load <= ’0’; set <= "00"; wait for 200 ns; reset <= ’0’; load <= ’1’; wait for 200 ns; data <= "00001"; wait for 100 ns; sel <= "01"; load <= ’0’; wait for 200 ns; sel <= "10"; wait for 1000 ns; end process; end architecture test_reg; |
