allegro安装完毕后无法运行
allegro安装完毕后无法运行
提示说服务依赖不全, 不知如何解决.
希望各位高手能指教.
依照正常的操作安装完成, listen.dat也处理的很好, 就是Cadence License Manager服务一直无法启动, 提示说依赖的服务没启动, 不知道Cadence License Manager依赖什么服务
本来有2张图片上传, 但是没有显示, 不知什么原因
#Edit this license file and replace the "hostname" field below with your computer hostname
#Create 2 environment variables: "LM_LICENSE_FILE" and "CDS_LIC_FILE" , assign to both variable this value =>
#5280@{your host name}
#Install any Cadence Licence Manager from any cadence cdroms:
#(1) Feed the CD1, run setup.exe.
#(2) Select "Set-Up Licensing" and point this license file when prompted about a license file
#(3) Ignore the msg about the license can't be parsed if ther's any, this msg is fake , the license manager is already running perfectly.
#Once this License Manager installation is done, just select Install Products
#when prompted about controlfile.txt just makes the text box empty, and select items manualy...
依照, 以上的说明安装的, 但是Cadence License Manager一直无法启动.
晕, 一直不能显示图片
