FPGA处理PCM码,有谁做过,能否帮忙提供些资料,谢谢
RT
library ieee;
use ieee.std_logic_1164.all;
entity hdbne is
generic (
EncoderType : integer range 2 to 3 := 3; -- 3: HDB3 2: HDB2/B3ZS
PulseActiveState : std_logic := '1' -- active state of P and N outputs
port (
Reset_i : in std_logic := '0'; -- active high async reset
Clk_i : in std_logic; -- rising edge clock
ClkEnable_i : in std_logic := '1'; -- active high clock enable
Data_i : in std_logic; -- active high data input
OutputGate_i : in std_logic := '1'; -- '0' forces P and N to not PulseActiveState (synchronously, but ignoring ClkEnable)
P_o : out std_logic; -- encoded +ve pulse output
N_o : out std_logic -- encoded -ve pulse output
end hdbne; -- End entity hdbne
architecture rtl of hdbne is
signal Q1 : std_logic; -- Q1 through Q5 form a shift
signal Q2 : std_logic; -- register for aligning
signal Q3 : std_logic; -- the data so we can insert
signal Q4 : std_logic; -- the violations
signal Q5 : std_logic;
signal AMI : std_logic; -- sense of pulse (P or N)
signal ViolationType : std_logic; -- sense of violation
signal ZeroCount : integer range 0 to 3; -- counts 0s in input
signal ZeroString : std_logic; -- goes to '1' when 3 or 4 0s seen
signal ZeroStringDelayed : std_logic; -- above delayed by 1 clock
begin
-- PROCESS : RegisterInput
-- DESCRIPTION: DFF (Q1) to register input data (reduces fan-in, etc)
RegisterInput: process (Reset_i, Clk_i)
begin
if Reset_i = '1' then
Q1 <= '0';
elsif rising_edge(Clk_i) then
if ClkEnable_i = '1' then
Q1 <= to_X01(Data_i);
end if;
end if;
end process RegisterInput;
-- PROCESS : CountZeros
-- DESCRIPTION: count number of contiguous zeros in input (mod 4 or mod 3)
CountZeros: process (Reset_i, Clk_i)
begin
ZeroCount <= 0;
if Q1 = '1' then
ZeroCount <= 0; -- have seen a 1, reset count
elsif ZeroCount >= EncoderType then
ZeroCount <= 0; -- increment modulo 3 or 4
else
ZeroCount <= ZeroCount + 1; -- increment
end if;
end if;
end if;
end process CountZeros;
-- PROCESS : DecodeCount (combinatorial)
-- DESCRIPTION: decode ZeroCount to indicate when string of 3 or 4 zeros is present
-- Note: this process is not clocked
DecodeCount: process (Q1, ZeroCount)
begin
if ZeroCount = EncoderType and Q1 = '0' then
ZeroString <= '1';
else
ZeroString <= '0';
end if;
end process DecodeCount;
-- PROCESS : RegisterZeroString
-- DESCRIPTION: DFF to register the ZeroString signal
RegisterZeroString: process (Reset_i, Clk_i)
begin
ZeroStringDelayed <= '0';
ZeroStringDelayed <= ZeroString;
end if;
end if;
end process RegisterZeroString;
-- PROCESS : DelayData
-- DESCRIPTION: insert 1 if needed for violation, and delay data by 2 or 3 clocks
-- to line up with ZeroString detection.
DelayData: process (Reset_i, Clk_i)
begin
Q2 <= '0';
Q3 <= '0';
Q4 <= '0';
Q2 <= Q1 or ZeroString; -- insert Violation bit
Q3 <= Q2;
if EncoderType = 3 then
-- HDB3, delay by 3 clocks
Q4 <= Q3;
else
-- HDB2, delay by 2 clocks
Q4 <= Q2; -- skip Q3
end if;
end if;
end if;
end process DelayData;
-- PROCESS : InsertBBit
-- DESCRIPTION: Delay Q4 by one clock, and insert B bit if needed.
InsertBBit: process (Reset_i, Clk_i)
begin
Q5 <= '0';
Q5 <= Q4 or (ZeroString and (not ViolationType));
end if;
end if;
end process InsertBBit;
-- PROCESS : ToggleViolationType
-- DESCRIPTION: Toggle ViolationType whenever Q5 is 1
ToggleViolationType: process (Reset_i, Clk_i)
begin
ViolationType <= '0';
ViolationType <= ViolationType xor Q5;
end if;
end if;
end process ToggleViolationType;
-- PROCESS : AMIFlipFlop
-- DESCRIPTION: toggle AMI to alternate P and N pulses. Force a violation (no
-- toggle) occasionally.
AMIFlipFlop: process (Reset_i, Clk_i)
begin
AMI <= '0';
AMI <= AMI xor (Q5 and (ViolationType nand (ZeroString or ZeroStringDelayed)));
end if;
end if;
end process AMIFlipFlop;
-- PROCESS : MakePandNPulses
-- DESCRIPTION: Gate Q5 with AMI to produce the P and N outputs
-- Note that OutputEnable overrides ClkEnable, to allow creation of
-- half width pulses.
-- The flip flops P and N will drive the outputs to the LIU, and these
-- flip flops should be in the IOBs in an FPGA. Clk to output delay
-- should be matched for P and N to avoid pulse shape distortion at the LIU
-- output.
MakePandNPulses: process (Reset_i, Clk_i)
begin
P_o <= not PulseActiveState;
N_o <= not PulseActiveState;
if ClkEnable_i = '1' or OutputGate_i /= '1' then
if OutputGate_i /= '1' then
-- force output to '0'
else
-- normal operation
if Q5 = '1' then
if AMI = '1' then
-- output '1' on P
P_o <= PulseActiveState;
else
-- output '1' on N
N_o <= PulseActiveState;
end if;
else
-- output '0'
end if;
end if;
end if;
end if;
end process MakePandNPulses;
end rtl; -- End architecture rtl;
-- End of hdbne.vhd
