(2)提供仿真信号 提供仿真信号可以有两种方法:绝对时间仿真和相对时间仿真。在绝对时间仿真方法中,仿真时间只是相对于零时刻的仿真时间。在相对时间仿真方法中,仿真的时间首先提供一个初值,在后继的时间设置中相对于该初始时间进行事件动作。
绝对时间仿真: MainStimulus: process begin Reset <= ’1’; Load <= ’0’; Count_UpDn <= ’0’; wait for 100 ns; Reset <= ’0’; wait for 20 ns; Load <= ’1’; wait for 20 ns; Count_UpDn <= ’1’; end process;
相对时间仿真: Process (Clock) Begin If rising_edge(Clock) then TB_Count <= TB_Count + 1; end if; end process; SecondStimulus: process begin if (TB_Count <= 5) then Reset <= ’1’; Load <= ’0’; Count_UpDn <= ’0’; Else Reset <= ’0’; Load <= ‘1’; Count_UpDn <= ‘1’; end process; FinalStimulus: process begin if (Count = "1100") then Count_UpDn <= '0'; report "Terminal Count Reached, now counting down." end if; end process;
(3)显示结果 VHDL提供标准的std_textio函数包把输入输出结果显示在终端上。
5.简单的仿真程序 library IEEE; use IEEE.std_logic_1164.all; entity testbench is end entity testbench; architecture test_reg of testbench component shift_reg is port (clock : in std_logic; reset : in std_logic; load : in std_logic; sel : in std_logic_vector(1 downto 0); data : in std_logic_vector(4 downto 0); shiftreg : out std_logic_vector(4 downto 0)); end component; signal clock, reset, load: std_logic; signal shiftreg, data: std_logic_vector(4 downto 0); signal sel: std_logic_vector(1 downto 0); constant ClockPeriod : TIME := 50 ns; begin UUT : shift_reg port map (clock => clock, reset => reset, load => load, data => data, shiftreg => shiftreg); process begin clock <= not clock after (ClockPeriod / 2); end process; process begin reset <= ’1’; data <= "00000"; load <= ’0’; set <= "00"; wait for 200 ns; reset <= ’0’; load <= ’1’; wait for 200 ns; data <= "00001"; wait for 100 ns; sel <= "01"; load <= ’0’; wait for 200 ns; sel <= "10"; wait for 1000 ns; end process; end architecture test_reg; |
