[求助][求助]flash-programmer下载遇到 No CFI table found at address
No CFI table found at address 0x0120000
试过网上所说的把外面 的接口改成birdir,不行
请高手帮忙下
这是一个比较常见的问题,你的配置targetboard有问题,你可以看看下面的链接:
flash的讨论 http://bbs.eccn.com/ecbbs/dispbbs.asp?boardID=9&ID=36154&page=2
当然也有可能是硬件的问题,你可以试试下面的flash测试程序。
#include <stdio.h>
#include <sys/alt_flash.h>
#include "system.h"
#include <unistd.h>
#define DATA_OFFSET 0x300000
int main(void)
alt_flash_fd* flash_handle;
FILE *uart;
char write_data = 0;
char read_data = 0;
write_data = 100;
uart = fopen(UART_NAME,"w");
flash_handle = alt_flash_open_dev(CFI_FLASH_NAME);
fprintf(uart, "open flash device...\n");
usleep(10000);
if (flash_handle)
fprintf(uart, "open flash device successed!!!\n");
usleep(10000);
alt_write_flash(flash_handle, DATA_OFFSET, &write_data, 1);
fprintf(uart, "wirte_data = %d\n", write_data);
usleep(10000);
alt_read_flash(flash_handle, DATA_OFFSET, &read_data, 1);
fprintf(uart, "read_data = %d\n", read_data);
usleep(10000);
if(read_data == write_data)
fprintf(uart, "flash write and read successed!!!\n");
usleep(10000);
else
fprintf(uart, "flash write or read failed!!!\n");
usleep(10000);
alt_flash_close_dev(flash_handle);
fprintf(uart, "close flash device...\n");
usleep(10000);
else
fprintf(uart, "open flash device failed!!!\n");
usleep(10000);
这个版主不太冷 =========================== 我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm
