Common Problems That Cause TLD.LOG To Overflow
The second error looks like this:
log_dis:possible pbq database corruption cannot open events file for board boardname, not a directory log_dis:file hp3070/qm/logdata/pbqmq/somedatafile error updating pbq database
What's Happening:
If thisis the case, you'll find files - not directories - in the /hp3070/qm/logdata/testerq directory. These files will likely be from a new board that you haven't yet run with "learn on". The "learn on" command creates the directories where the pbq data is temporarily stored while it is being processed.
How to fix it:
If you see this error,
Remove the files
(but not the directories
) under testerq
Run the board with "learn on" once.
Turn "learn off"
Then the files should be put in the appropriate board directories.
Question:
Common problems that cause tld.log to overflow.
Answer:
(Date: Mar 97: Version B.02.XX)  There are three very common errors that will cause the /hp3070/qm/logdata/tld.log file to grow very quickly, and eventually cause the tld.log file to overflow. You may discover an error that goes to your console screen (and writes over windows) that says that tld.log has exceeded the max size.
These three common errors are easy to fix.
The first error looks like this:
"*(970407 time):/hp3070/qm/logdata/testerq/970306092821hp3070a1"
We have also seen this error:
log_dis: possible pbq database corruption: cannot open events for file &ltbunch of numbers>: not a directory
log_dis: file /hp3070/qm/logdata/pbqmq/&ltdate code>&ltsystem name> error updating pbq database! Fix problem, then try again
What's Happening:
The /hp3070/qm/logdata/testerq directory is a temporary storage area. The translogd daemon processes this data and places it under individual board directories under the /hp3070/qm/pbq directory. If the board directories don't exist, but references to them in the /hp3070/qm/pbq/boards file do exist, the data doesn't have a place to move to when translogd tries to move it out of the testerq directory. This situation usually occurs because someone has removed a board directory in UNIX, rather than removing the board through the qstats utilities.
How to solve it:
Look in /hp3070/qm/pbq. Compare the list of directories there with the list of board directories in the "boards" file. Find the entries in the "boards" file that do not have a directory under pbq.
Then, delete the entries in the /hp3070/qm/pbq/boards file which refer to the non-existent board directories. Also remove any files that remain in testerq that show up in the error messages in the tld.log file. They usually come in groups that have very similar timestamps as part of the name, so thisshould be relatively easy to do.
If, when you deleted entries in the boards file, you removed the name of a board that you still run production on, run the board with "learn on" once. The daemon will then recreate the boards file entries and the board directories and then move the data to these directories. Then turn "learn off".
You may have removed some boards from the file that don't have directories any more, and that you don't run production on any more. You don't need to do anything else with these boards.
If there is a lot of data stacked up under pbqmq, it may take a while to move all this data. With time, the number of files under pbqmq should decrease.
The third error looks like this:
A third problem produces error messages similar to the second one, but the cause is a little bit different. The tld.log file will have error messages in it that look like this:
BAD DIRECTORY PATH IGNORED [970326 14:49]: /hp3070/qm/logdata/testerq/somedatafile
* [ 970326  14:49]:
* [ 970326  14:50]:
* [ 970326  14:50]:
* [ 970326  14:51]:
* [ 970326  14:51]:
* [ 970326  14:52]:
* [ 970326  14:52]:
What's Happening:
Every thirty seconds, you'll get another line similar to the above. The cause of this problem is a file (not a directory ) that's located in the /hp3070/qm/logdata/testerq directory. This can happen if the testplan has a Board$ variable set to a null string ("").
We have seen this happen when an operator was prompted to select a version of a card when they had a multiple-version card - and the operator entered a null string. Unfortunately, no error checking was done on the operator's input, so the Board$ string was created as "".
If the testplan is continually run, several files will be deposited in the board directory, and you'll get a new error message for each one every thirty seconds, so your tld.log file will fill up quickly.
How to fix it:
The cure for this problem is to remove the files from the testerq directory, and fix any testplans that allow the Board$ string to be set to "".
Additional Notes:
Once you've looked at the problems, and taken steps to solve them, you may have to shorten your tld.log file. A good way to do this is:
cd /hp3070/qm/logdata
> tld.log
This truncates your tld.log file to 0 length, but preserves the ownerships and permissions. Make certain that you have solved the problem before you shorten this file: the information in tld.log is useful for solving other problems with datalogging, so if you have a problem that's more complex than the ones described here, your support person will probably need some of the information from this file.
Please do not remove your tld.log file!
It must exist so that error messages from translogd can be written correctly. Otherwise, you'll lose track of anything that's going wrong with translogd.
If the error messages you're seeing do not match the ones shown above, please contact your HP Support Representative so that we can help you solve the problem.
