[求助]NIOS IDE烧FLASH问题求解
我用的是QUARTUS7.0与NIOS2 7.0一起来做的,在烧FLASH的时候出现以下问题:
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd D:/altera/70/nios2eds/bin/eclipse/nios2-ide-workspace-7.0/hello_led_3/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="D:/cpu/soc.sof" --output="soc.fl
ash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=soc.op
t D:/cpu/soc.sof soc.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Allocated 124 megabytes of memory during processing
Info: Processing ended: Wed Dec 26 16:18:57 2007
Info: Elapsed time: 00:00:10
Info: Command: quartus_cpf --no_banner --convert soc.pof soc.rpd
Info: Allocated 52 megabytes of memory during processing
Info: Processing ended: Wed Dec 26 16:19:03 2007
Info: Elapsed time: 00:00:05
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x05000800 --instance
=0 "soc.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
: Checksumming existing contents
00000000 : Verifying existing contents
00010000 : Verifying existing contents
00020000 : Verifying existing contents
00030000 : Verifying existing contents
00040000 : Verifying existing contents
00050000 : Verifying existing contents
00060000 : Verifying existing contents
00070000 : Verifying existing contents
00080000 : Verifying existing contents
00090000 : Verifying existing contents
000A0000 : Verifying existing contents
00000000 : Reading existing contents
00010000 : Reading existing contents
00020000 : Reading existing contents
00030000 : Reading existing contents
00040000 : Reading existing contents
00050000 : Reading existing contents
00060000 : Reading existing contents
00070000 : Reading existing contents
00080000 : Reading existing contents
00090000 : Reading existing contents
000A0000 : Reading existing contents
Checksummed/read 704kB in 18.5s
00000000 ( 0%): Erasing
00010000 ( 9%): Erasing
00020000 (18%): Erasing
00030000 (27%): Erasing
00040000 (36%): Erasing
00050000 (45%): Erasing
00060000 (54%): Erasing
00070000 (63%): Erasing
00080000 (72%): Erasing
00090000 (81%): Erasing
000A0000 (90%): Erasing
Erased 704kB in 10.0s (70.4kB/s)
00000000 ( 0%): Programming
Program failed
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x04000000 --end=0x47fffff --reset=0x4000
000 --input="hello_led_3.elf" --output="flash.flash" --boot="D:/altera/70/ip/nio
s2_ip/altera_nios2/boot_loader_cfi.srec"
# Programming flash with the project
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x04000000 --instance=0 "fla
sh.flash"
Resetting and pausing target processor: No CFI table found at address 0x04000000
OK
# Creating .flash file for the datafile
"$SOPC_KIT_NIOS2/bin/bin2flash" --base=0x04000000 --location=0x0 --input="D:/bur
n/flash_uart.bin" --output="flash_uart.flash"
# Programming flash with the datafile
sh_uart.flash"
OK
大侠来帮忙啊..急
从提示看,你的CFI似乎没有设置好。你再好好检查你的设置。
CFI是按照DATASHEET来填,应该没问题,就是SOPC中的FLASH的开始地址是0X04000000,这个地址我无法改变的啊,现在很着急的啊,谢谢2楼的...
看NIOS的这个提示说明可以擦除了,但是编程为什么就不行了呢?困绕很久了啊.
你用什么板子啊?
看以前也遇到过烧不进去的情况。将FLASH IC的WP短接一下再烧试试吧。不排除这样的原因。
