请教EDK中的一个起步问题?也就是新手问题
从某人那里弄到一块很老的板子,SpartanII XC2S100的,想试试能不能用MicroBlaze,于是装了ISE8.2和EDK8.2。用向导建立工程,选择自定义电路板,然后一步一步往下,修改UCF文件和那个download文件,然后genertate netlist的时候报错:错误太长了,总之就是我没有改动任何东西,除了上述两个文件以外,但是就是不能generatenetlist。
At Local date and time: Tue Jan 01 22:51:51 2008
xbash -q -c "cd /cygdrive/d/Study/fpga_cpld/works/edk/1/; /usr/bin/make -f system.make netlist; exit;" started...
Creating system netlist for hardware specification..
platgen -p xc2s100pq208-6 -lang vhdl system.mhs
Release Xilinx EDK 8.2 - platgen EDK_Im.14
Copyright (c) 1995-2006 Xilinx, Inc. All rights reserved.
Command Line: platgen -p xc2s100pq208-6 -lang vhdl system.mhs
Parse system.mhs ...
Read MPD definitions ...
Sourcing tcl file
D:/EDK/hw/XilinxProcessorIPLib/pcores/microblaze_v4_00_a/data/microblaze_v2_1_0.
tcl ...
Sourcing tcl file
D:/EDK/hw/XilinxProcessorIPLib/pcores/opb_mdm_v2_00_a/data/opb_mdm_v2_1_0.tcl
Sourcing tcl file
D:/EDK/hw/XilinxProcessorIPLib/pcores/lmb_v10_v1_00_a/data/lmb_v10_v2_1_0.tcl
Sourcing tcl file
D:/EDK/hw/XilinxProcessorIPLib/pcores/lmb_bram_if_cntlr_v1_00_b/data/lmb_bram_if
_cntlr_v2_1_0.tcl ...
Overriding IP level properties ...
microblaze (microblaze_0) -
D:\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v4_00_a\data\microblaze_v2_1_0.
mpd line 63 - tool overriding c_family value virtex2 to spartan2
mpd line 64 - tool overriding c_instance value microblaze to microblaze_0
mpd line 93 - tcl overriding C_ADDR_TAG_BITS value 17 to 0
mpd line 100 - tcl overriding C_DCACHE_ADDR_TAG value 17 to 0
opb_mdm (debug_module) -
D:\EDK\hw\XilinxProcessorIPLib\pcores\opb_mdm_v2_00_a\data\opb_mdm_v2_1_0.mpd
line 42 - tool overriding c_family value virtex2 to spartan2
bram_block (lmb_bram) -
D:\EDK\hw\XilinxProcessorIPLib\pcores\bram_block_v1_00_a\data\bram_block_v2_1_0.
mpd line 42 - tool overriding c_family value virtex2 to spartan2
opb_gpio (leds) -
D:\EDK\hw\XilinxProcessorIPLib\pcores\opb_gpio_v3_01_b\data\opb_gpio_v2_1_0.mpd
line 41 - tool overriding c_family value virtex2 to spartan2
Performing IP level DRCs on properties...
Running DRC Tcl procedures for OPTION IPLEVEL_DRC_PROC...
Sourcing tcl file
D:/EDK/hw/XilinxProcessorIPLib/pcores/bram_if_cntlr_v1_00_b/data/bram_if_cntlr_v
2_1_0.tcl ...
Sourcing tcl file
2_1_0.tcl ...
Address Map for Processor microblaze_0
(0x00000000-0x00001fff) dlmb_cntlr dlmb
(0x00000000-0x00001fff) ilmb_cntlr ilmb
(0x40000000-0x4000ffff) LEDS mb_opb
(0x41400000-0x4140ffff) debug_module mb_opb
Check platform address map ...
Overriding system level properties ...
opb_v20 (mb_opb) -
D:\EDK\hw\XilinxProcessorIPLib\pcores\opb_v20_v1_10_c\data\opb_v20_v2_1_0.mpd
line 39 - tool overriding c_num_masters value 4 to 2
opb_v20 (mb_opb) -
line 40 - tool overriding c_num_slaves value 4 to 2
lmb_v10 (ilmb) -
D:\EDK\hw\XilinxProcessorIPLib\pcores\lmb_v10_v1_00_a\data\lmb_v10_v2_1_0.mpd
line 39 - tool overriding c_lmb_num_slaves value 4 to 1
lmb_v10 (dlmb) -
lmb_bram_if_cntlr (dlmb_cntlr) -
D:\EDK\hw\XilinxProcessorIPLib\pcores\lmb_bram_if_cntlr_v1_00_b\data\lmb_bram_if
_cntlr_v2_1_0.mpd line 45 - tool overriding c_mask value 0x00800000 to
0x40000000
lmb_bram_if_cntlr (ilmb_cntlr) -
0x40000000
mpd line 38 - tool overriding c_memsize value 2048 to 0x2000
Running DRC Tcl procedures for OPTION SYSLEVEL_DRC_PROC...
Performing System level DRCs on properties...
Check platform configuration ...
WARNING:MDT - microblaze (microblaze_0) -
D:\Study\fpga_cpld\works\edk\1\system.mhs line 24 - deprecated core!
WARNING:MDT - lmb_bram_if_cntlr (dlmb_cntlr) -
D:\Study\fpga_cpld\works\edk\1\system.mhs line 83 - deprecated core!
WARNING:MDT - lmb_bram_if_cntlr (ilmb_cntlr) -
D:\Study\fpga_cpld\works\edk\1\system.mhs line 92 - deprecated core!
ERROR:MDT - lmb_bram_if_cntlr (ilmb_cntlr) -
D:\Study\fpga_cpld\works\edk\1\system.mhs line 92 - Memory of data width
32-bit and memory size 8-kBytes does not fit in a fixed size.
Only the following memory configurations are supported:
| Memory (kBytes) | Memory (kBytes)
Architecture | 32-bit data | 64-bit data
| byte-write | byte-write
Spartan-II | 2 4 | 4
Spartan-IIE | 2 4 8 16 | 4 8 16 32
Spartan-3 | 8 16 32 64 | 16 32 64 128
Spartan-3E | 8 16 32 64 | 16 32 64 128
QPro Virtex | 2 4 8 16 | 4 8 16 32
QPro VirtexE | 2 4 8 16 | 4 8 16 32
QPro Virtex-II | 8 16 32 64 | 16 32 64 128
QPro-R Virtex | 2 4 8 16 | 4 8 16 32
QPro-R Virtex-II | 8 16 32 64 | 16 32 64 128
Virtex-II PRO | 8 16 32 64 | 16 32 64 128
Virtex-4 | 2 4 8 16 32 64 128 | 4 8 16 32 64 128 256
Virtex-5 | 4 8 16 32 64 128 256 | 8 16 32 64 128 256 512
ERROR:MDT - lmb_bram_if_cntlr (dlmb_cntlr) -
D:\Study\fpga_cpld\works\edk\1\system.mhs line 83 - Memory of data width
QP
opb_v20 (mb_opb) - D:\Study\fpga_cpld\works\edk\1\system.mhs line 42 - 2
master(s) : 2 slave(s)
lmb_v10 (ilmb) - D:\Study\fpga_cpld\works\edk\1\system.mhs line 67 - 1 master(s)
: 1 slave(s)
lmb_v10 (dlmb) - D:\Study\fpga_cpld\works\edk\1\system.mhs line 75 - 1 master(s)
: 1 slave(s)
Running UPDATE Tcl procedures for OPTION PLATGEN_SYSLEVEL_UPDATE_PROC...
ERROR:MDT - platgen failed with errors!
make: *** [implementation/microblaze_0_wrapper.ngc] Error 2
Done!
请高手耐心看完,由于第一次使用,没有教程和书籍,只好来麻烦大家了
[此贴子已经被作者于2008-1-1 23:23:01编辑过]
搞清楚了,只是因为SPARTAN II 只支持4k 8k 的 存储器大小。在mhs文件里或者system Assembly View中将地址改小至4K就行了,但是……接下来发现其他的错误了,请看下一个帖子“xilinx 8.2i 版本问题”
[此贴子已经被作者于2008-1-2 16:18:50编辑过]
