两相正弦波VHDL程序
两相正弦波VHDL程序
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity interface is
port(clk:in std_logic;
REFAut std_logic_vector(13 downto 0);
REFBut std_logic_vector(13 downto 0));
end ;
architecture dacc of interface is
component datarom
port(address: in std_logic_vector(3 downto 0);
inclock: in std_logic;
Q: out std_logic_vector(13 downto 0));
end component ;
signal Q1: std_logic_vector(3 downto 0);
begin
process(clk)
begin
if clk'event and clk='1' then Q1<=Q1+1;
end if ;
end process;
U1:datarom port map (address=>Q1,Q=>REFA,inclock=>clk);
U2:datarom port map (address=>Q1+4,Q=>REFB,inclock=>clk);
end;
lz使用dds来实现sin波形的吗?
这个只是顶层的连接图描述,要是能补全才有意义啊
这个版主不太冷 =========================== 我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm
就是没意思,怎么不给点核心的呢?
