capture 生成 netlist的问题请求帮忙
各位大虾,要帮帮小弟啊~~~~!! 我在生成网表出现了如下错误信息,我是第一次画,遇到这样的问题都不知怎么解决,书上也没说,请求帮忙 请告诉我是什么问题,如何解决,谢谢了! ******************************************************************************** * * Netlisting the design * ******************************************************************************** Design Name: D:\Cadence\SPB_15.7\document\capture\mfrc500\mfrc500_project2.dsn Netlist Directory: D:\CADENCE\SPB_15.7\DOCUMENT\CAPTURE\MFRC500\ALLEGRO Configuration File: D:\Cadence\SPB_15.7\tools\capture\allegro.cfg Spawning... "D:\Cadence\SPB_15.7\tools\capture\pstswp.exe" -pst -d "D:\Cadence\SPB_15.7\document\capture\mfrc500\mfrc500_project2.dsn" -n "D:\CADENCE\SPB_15.7\DOCUMENT\CAPTURE\MFRC500\ALLEGRO" -c "D:\Cadence\SPB_15.7\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint" #1 Warning [ALG0016] Part Name "CONNECTOR DB9_0_DB9_CONNECTOR DB9" is renamed to "CONNECTOR DB9_0_DB9_CONNECTOR D". #2 Warning [ALG0016] Part Name "PHONEJACK STEREO_DC-208_9V_DC_IN" is renamed to "PHONEJACK STEREO_DC-208_9V_DC_I". #3 Warning [ALG0016] Part Name "LED BI-COLOUR_5_SIP3_LED BI-COLOUR" is renamed to "LED BI-COLOUR_5_SIP3_LED BI-COL". #4 Warning [ALG0016] Part Name "RESISTOR SIP 2_R0603_RESISTOR SIP 2" is renamed to "RESISTOR SIP 2_R0603_RESISTOR S". #5 Warning [ALG0016] Part Name "AT89C51RD2 PQFP44_0_PQFP44_AT89C51RD2 PQFP44" is renamed to "AT89C51RD2 PQFP44_0_PQFP44_AT89". #6 Warning [ALG0016] Part Name "MFRC500 SOP32_SO32_MFRC500 SOP32" is renamed to "MFRC500 SOP32_SO32_MFRC500 SOP3". #7 Warning [ALG0016] Part Name "LP38690DT-5_0.0 TO253_TO253_LP38690DT-5.0 TO253" is renamed to "LP38690DT-5_0.0 TO253_TO253_LP3". Scanning netlist files ... Loading... D:\CADENCE\SPB_15.7\DOCUMENT\CAPTURE\MFRC500\ALLEGRO/pstchip.dat Loading... D:\CADENCE\SPB_15.7\DOCUMENT\CAPTURE\MFRC500\ALLEGRO/pstchip.dat Loading... D:\CADENCE\SPB_15.7\DOCUMENT\CAPTURE\MFRC500\ALLEGRO/pstxprt.dat #38 DDB_ERROR: Terminating character ':' not found on line 263. DDB_INFO: File D:\CADENCE\SPB_15.7\DOCUMENT\CAPTURE\MFRC500\ALLEGRO/pstxprt.dat not loaded. Error: Line 263 in file D:\CADENCE\SPB_15.7\DOCUMENT\CAPTURE\MFRC500\ALLEGRO/pstxprt.dat: Error loading the parts list file Detected in function: ddbLoadPstXFiles #8 Error [ALG0036] Unable to read logical netlist data. Exiting... "D:\Cadence\SPB_15.7\tools\capture\pstswp.exe" -pst -d "D:\Cadence\SPB_15.7\document\capture\mfrc500\mfrc500_project2.dsn" -n "D:\CADENCE\SPB_15.7\DOCUMENT\CAPTURE\MFRC500\ALLEGRO" -c "D:\Cadence\SPB_15.7\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint" *** Done ***
