常用的ASIC_FPGA IP cores 可以提供,需要的联系
新的ASIC/FPGA设计的digital & analog IP cores可以提供,如需要可email联系
-8bit 1T/2T/4T/12T MCU
8bit RISC CPU
Turbo 186
V6502
V8086
16bit MCU
32bit RISC CPU
IBM PowerPC405
IBM PowerPC440
IBM PowerPCPLB
Audio Echo Processor
16/24 bit DSP Core
16bit audio DAC (Digital design parts)
- Interface IP:
Usb1.0 Host/Device/Hub
Usb1.0 Low speed/Full speed PHY
Usb2.0 Host/Device/OTG controller
USB2.0 HS/OTG PHY @180nm/130nm/90nm/65nm (TSMC/SMIC/IBM/Charted process)
USB2.0 mobile PHY @130nm/90nm/65nm (TSMC/SMIC/IBM/Charted process)
Wireless USB controller
PCI/PCI-X
PCI-Express endpoint/rootmode/swtich brige controller
PCI-Express PHY @130nm/90nm/65nm (TSMC/SMIC process)
IEEE1394 Controller
Ethernet 10/100/1000 Controller
Ethernet 10G MAC controller & PHY
IDE controoler
SATA host/device Controller
SATA PHY @130nm/90nm (TSMC/SMIC process)
Media Local BUS IP
SD_MMC host controller IP
LCD controller
MemoryStick Host controller
Smart card reader
AMBA2.0/3.0 IP
AMBA Interface IP
DDR/DDR-II memory controller
DDR/DDR-II IO
DDR/DDR-II SDRAM PHY
Mobile Storage controller (include SDIO/CEVA/MMC host controller)
SDIO device controller
WLAN AFE IP
TSMC PLL
Nand Flash controller
CMOS Sensor Interface IP
DDR3/DDR2/DDR memory controller IP
DDR2/DDR SDRAM PHY
DDR2/DDR3 SDRAM PHY
SPDIF Interface IP
- JPEG Encoder/Decoder/Codec
Motion-JPEG
MPEG2 Decoder
H264/MPEG4 codec
H264/MPEG4 decoder
H264/MPEG4 encoder
MPEG4 encoder
2D graphics core
3D graphics core
TV encoder
另外还提供各种各样得synopsys & cadence & mentor & magma
等ASIC设计EDA平台(windows & linux & Solaris版本),有需要
可以email联系详细谈。
Email: soft_cores@163.com
现在做sopc的公司的确很多,有了ip核,集成的资料的确也很重要的。
这个版主不太冷 =========================== 我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm
