[求助]求助 modelsim 6.3 的破解方法
1.Install, Select Full product instllation. When asked for security key, select no. When you see License Wizard dialog, select close because license wizard dont know our license's format. 2.Use our keygen to generate license.dat, copy it to c:\flexlm directory. 3.set enviroment string: LM_LICENSE_FILE = c:\flexlm\license.dat 4.Start Modelsim and have fun. 其中设置环境变量的方法楼主可以百度一下就知道了。在“我的电脑,属性”里设置 |
这个版主不太冷
我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm |
