EDK中为什么不能实现中断?
EDK中为什么不能实现中断?
程序源代码如下:
#include "xparameters.h"
#include "stdio.h"
#include "xintc_l.h"
#include "xutil.h"
#include "xgpio_l.h"
#include "mb_interface.h"
#define XPAR_GPIO_REG_BASE XPAR_LEDS_8BIT_BASEADDR
#define LED_DELAY 2500000
#define LED_CHANNEL 1
Xuint8 Data=0xaa;
Xuint8 Data2=0x0f;
void switch_int_handler(void *baseaddr_p)
Data=0x00;
Data2=0x00;
XGpio_mWriteReg(XPAR_DIP_SWITCHES_4BIT_BASEADDR,XGPIO_ISR_OFFSET,0x00000001);
microblaze_disable_interrupts();
int main()
volatile int Delay;
/* Set the direction of gpio */
XGpio_mSetDataDirection(XPAR_GPIO_REG_BASE, LED_CHANNEL, 0x0);
XGpio_mSetDataDirection(XPAR_DIP_SWITCHES_4BIT_BASEADDR,1,0xffffffff);
// Initializing the interrupt vector
* Enable the Interrupts on the Microblaze
microblaze_enable_interrupts();
* Register the switch_gpio interrupt handler in the vector table
XIntc_RegisterHandler(XPAR_OPB_INTC_0_BASEADDR,
XPAR_OPB_INTC_0_DIP_SWITCHES_4BIT_IP2INTC_IRPT_INTR,
(XInterruptHandler)switch_int_handler,
(void *)XPAR_DIP_SWITCHES_4BIT_BASEADDR);
* Start the interrupt controller
XIntc_mMasterEnable(XPAR_OPB_INTC_0_BASEADDR);
* Set the master enable bit.
XIntc_Out32(XPAR_OPB_INTC_0_BASEADDR + XIN_MER_OFFSET,
XIN_INT_MASTER_ENABLE_MASK);*/
* Enable timer and uart interrupt requests in the interrupt controller
XIntc_mEnableIntr(XPAR_OPB_INTC_0_BASEADDR,
XPAR_DIP_SWITCHES_4BIT_IP2INTC_IRPT_MASK);
// Enable interrupt of GPIO
XGpio_mWriteReg(XPAR_DIP_SWITCHES_4BIT_BASEADDR,XGPIO_GIER_OFFSET,0x80000000);
XGpio_mWriteReg(XPAR_DIP_SWITCHES_4BIT_BASEADDR,XGPIO_IER_OFFSET,0x00000001);
while (1)
if (XGpio_mGetDataReg(XPAR_DIP_SWITCHES_4BIT_BASEADDR,1)&1)
XGpio_mSetDataReg(XPAR_GPIO_REG_BASE, LED_CHANNEL,~Data);
else
XGpio_mSetDataReg(XPAR_GPIO_REG_BASE, LED_CHANNEL,Data);
/* Wait a small amount of time so the LED is visible */
for (Delay = 0; Delay < LED_DELAY; Delay++);
XGpio_mSetDataReg(XPAR_GPIO_REG_BASE, LED_CHANNEL, Data2);
else
XGpio_mSetDataReg(XPAR_GPIO_REG_BASE, LED_CHANNEL,~Data2);
return 0;
MHS文件如下:
PARAMETER VERSION = 2.1.0
PORT fpga_0_LEDs_8Bit_GPIO_d_out_pin = fpga_0_LEDs_8Bit_GPIO_d_out, DIR = O, VEC = [0:7]
PORT fpga_0_DIP_Switches_4Bit_GPIO_in_pin = fpga_0_DIP_Switches_4Bit_GPIO_in, DIR = I, VEC = [0:3]
PORT sys_clk_pin = dcm_clk_s, DIR = I, SIGIS = CLK, CLK_FREQ = 50000000
PORT sys_rst_pin = sys_rst_s, DIR = I, RST_POLARITY = 1, SIGIS = RST
BEGIN microblaze
PARAMETER INSTANCE = microblaze_0
PARAMETER HW_VER = 6.00.a
PARAMETER C_USE_FPU = 0
PARAMETER C_DEBUG_ENABLED = 1
PARAMETER C_NUMBER_OF_PC_BRK = 2
PARAMETER C_AREA_OPTIMIZED = 1
BUS_INTERFACE DLMB = dlmb
BUS_INTERFACE ILMB = ilmb
BUS_INTERFACE DOPB = mb_opb
BUS_INTERFACE IOPB = mb_opb
PORT DBG_CAPTURE = DBG_CAPTURE_s
PORT DBG_CLK = DBG_CLK_s
PORT DBG_REG_EN = DBG_REG_EN_s
PORT DBG_TDI = DBG_TDI_s
PORT DBG_TDO = DBG_TDO_s
PORT DBG_UPDATE = DBG_UPDATE_s
PORT Interrupt = Interrupt
END
BEGIN opb_v20
PARAMETER INSTANCE = mb_opb
PARAMETER HW_VER = 1.10.c
PARAMETER C_EXT_RESET_HIGH = 1
PORT SYS_Rst = sys_rst_s
PORT OPB_Clk = sys_clk_s
END
BEGIN opb_mdm
PARAMETER INSTANCE = debug_module
PARAMETER HW_VER = 2.00.a
PARAMETER C_MB_DBG_PORTS = 1
PARAMETER C_USE_UART = 1
PARAMETER C_UART_WIDTH = 8
PARAMETER C_BASEADDR = 0x41400000
PARAMETER C_HIGHADDR = 0x4140ffff
BUS_INTERFACE SOPB = mb_opb
PORT DBG_CAPTURE_0 = DBG_CAPTURE_s
PORT DBG_CLK_0 = DBG_CLK_s
PORT DBG_REG_EN_0 = DBG_REG_EN_s
PORT DBG_TDI_0 = DBG_TDI_s
PORT DBG_TDO_0 = DBG_TDO_s
PORT DBG_UPDATE_0 = DBG_UPDATE_s
END
BEGIN lmb_v10
PARAMETER INSTANCE = ilmb
PARAMETER HW_VER = 1.00.a
PORT LMB_Clk = sys_clk_s
END
BEGIN lmb_v10
PARAMETER INSTANCE = dlmb
END
BEGIN lmb_bram_if_cntlr
PARAMETER INSTANCE = dlmb_cntlr
PARAMETER C_BASEADDR = 0x00000000
PARAMETER C_HIGHADDR = 0x00001fff
BUS_INTERFACE SLMB = dlmb
BUS_INTERFACE BRAM_PORT = dlmb_port
END
PARAMETER INSTANCE = ilmb_cntlr
BUS_INTERFACE SLMB = ilmb
BUS_INTERFACE BRAM_PORT = ilmb_port
END
BEGIN bram_block
PARAMETER INSTANCE = lmb_bram
BUS_INTERFACE PORTA = ilmb_port
BUS_INTERFACE PORTB = dlmb_port
END
BEGIN opb_gpio
PARAMETER INSTANCE = LEDs_8Bit
PARAMETER HW_VER = 3.01.b
PARAMETER C_GPIO_WIDTH = 8
PARAMETER C_IS_DUAL = 0
PARAMETER C_IS_BIDIR = 0
PARAMETER C_ALL_INPUTS = 0
PARAMETER C_BASEADDR = 0x40020000
PARAMETER C_HIGHADDR = 0x4002ffff
PORT GPIO_d_out = fpga_0_LEDs_8Bit_GPIO_d_out
END
BEGIN opb_gpio
PARAMETER INSTANCE = DIP_Switches_4Bit
PARAMETER C_INTERRUPT_PRESENT = 1
PARAMETER C_GPIO_WIDTH = 4
PARAMETER C_ALL_INPUTS = 1
PARAMETER C_BASEADDR = 0x40000000
PARAMETER C_HIGHADDR = 0x4000ffff
PORT IP2INTC_Irpt = DIP_Switches_4Bit_IP2INTC_Irpt
PORT GPIO_in = fpga_0_DIP_Switches_4Bit_GPIO_in
END
BEGIN opb_intc
PARAMETER INSTANCE = opb_intc_0
PARAMETER HW_VER = 1.00.c
PARAMETER C_BASEADDR = 0x41200000
PARAMETER C_HIGHADDR = 0x4120ffff
PORT Irq = Interrupt
PORT Intr = DIP_Switches_4Bit_IP2INTC_Irpt
END
BEGIN dcm_module
PARAMETER INSTANCE = dcm_0
PARAMETER C_CLK0_BUF = TRUE
PARAMETER C_CLKIN_PERIOD = 20.000000
PARAMETER C_CLK_FEEDBACK = 1X
PORT CLKIN = dcm_clk_s
PORT CLK0 = sys_clk_s
PORT CLKFB = sys_clk_s
PORT RST = net_gnd
PORT LOCKED = dcm_0_lock
END
//感觉这个之前要先进行中断初始化,就是xintc_inint...的一个命令
