在EDK里边加了一个ICON和ILA核,出问题了,哪位高手能帮忙诊断下.EDK是9.1.02i版.chipscope pro是9.1.01i版本 IPNAME:plb_v34 INSTANCE:plb - E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chippro _video_capture_rev_1_1\system.mhs line 101 - 2 master(s) : 2 slave(s) IPNAME pb_v20 INSTANCE pb - E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chippro _video_capture_rev_1_1\system.mhs line 110 - 1 master(s) : 4 slave(s) Check port drivers... WARNING:MDT - INST:ppc405_0 PORT:C405CPMTIMERRESETREQ CONNECTOR:ppc405_0_C405CPMTIMERRESETREQ_to_chipscope_ila_0 - E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chip pro_video_capture_rev_1_1\system.mhs line 69 - floating connection! WARNING:MDT - INST:ppc405_0 PORT:C405DBGMSRWE CONNECTOR:ppc405_0_C405DBGMSRWE_to_chipscope_ila_0 - E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chip pro_video_capture_rev_1_1\system.mhs line 68 - floating connection! WARNING:MDT - INST:and_gate_0 PORT:Res CONNECTOR:vid_dec_rst - E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chip pro_video_capture_rev_1_1\system.mhs line 249 - floating connection! ERROR:MDT - INST:system PORT IXEL_CLOCK CONNECTOR IXEL_CLOCK - E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chip pro_video_capture_rev_1_1\system.mhs line 43 - connection cannot be read internally from entity/module! This creates an illegal HDL description. Declare an intermediate connector of a name other than the port name, and assign this to the output. Running UPDATE Tcl procedures for OPTION PLATGEN_SYSLEVEL_UPDATE_PROC... ********************************************** ********************************************** Created elaborate directory ERROR:MDT - chipscope_icon_0 (chipscope_icon) - Generating the core : chipscope_icon_0.... Chipscope Core Generator Error : ChipScope Pro Core Generator Version : 9.1.01i Build : 09101.7.12.910 Reading arguments from file E:/doc/V2P_CD/Reference_Designs/edk_7_1_builds/video_capture_rev_1_1/pal/chip pro_video_capture_rev_1_1/implementation/cs_coregen_chipscope_icon_0.arg Warning: Arguments from file will override command line arguments
Creating EDIF Netlist E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chip pro_video_capture_rev_1_1/implementation/chipscope_icon_0_wrapper/\icon_1.edn Component Name: icon_1 Device Family: Virtex2P Control port count: 1 Enable BSCAN instance: false BSCAN chain: USER1 Enable JTAG global clock buffer: true Enable unused BSCAN ports: false Force RPM Grid Usage: no Resource Utilization Estimate LUT:97 FF:28 BRAM:0 Warning: EDIF Netlist being generated Post Processing EDIF netlist E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chip pro_video_capture_rev_1_1/implementation/chipscope_icon_0_wrapper/\icon_1.edn Generating constraints file E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chip pro_video_capture_rev_1_1\implementation\chipscope_icon_0_wrapper\icon_1.ncf WARNING: Default charset GBK not supported, using ISO-8859-1 instead Please verify that the MHS Parameters for "chipscope_icon_0" core are valid and the generated Chipscope Core Generator arg file : "implementation/cs_coregen_chipscope_icon_0.arg" is valid ************************************************************* while executing "error "Generating the core : $params(INSTANCE).... Chipscope Core Generator Error : $err Please verify that the MHS Parameters for \"$params(INSTANC..." (procedure "::hw_chipscope_icon_v1_01_a::icon_generate" line 91) invoked from within "::hw_chipscope_icon_v1_01_a::icon_generate 40094040" ********************************************** ********************************************** ********************************************** ********************************************** Param values are : INSTANCE chipscope_ila_0 HW_VER 1.01.a C_FAMILY virtex2p C_DEVICE 2vp30 C_PACKAGE ff896 C_SPEEDGRADE -7 C_NUM_DATA_SAMPLES 512 C_ENABLE_TRIGGER_OUT 0 C_DATA_SAME_AS_TRIGGER 1 C_DATA_IN_WIDTH 32 C_DISABLE_RPM 0 C_DISABLE_SRL16S 0 C_RISING_CLOCK_EDGE 1 C_ENABLE_TRIGGER_SEQUENCER 0 C_MAX_SEQUENCER_LEVELS 16 C_ENABLE_STORAGE_QUALIFICATION 1 C_TRIG0_UNITS 1 C_TRIG0_TRIGGER_IN_WIDTH 8 C_TRIG0_UNIT_COUNTER_WIDTH 0 C_TRIG0_UNIT_MATCH_TYPE basic C_TRIG1_UNITS 0 C_TRIG1_TRIGGER_IN_WIDTH 8 C_TRIG1_UNIT_COUNTER_WIDTH 0 C_TRIG1_UNIT_MATCH_TYPE basic C_TRIG2_UNITS 0 C_TRIG2_TRIGGER_IN_WIDTH 8 C_TRIG2_UNIT_COUNTER_WIDTH 0 C_TRIG2_UNIT_MATCH_TYPE basic C_TRIG3_UNITS 0 C_TRIG3_TRIGGER_IN_WIDTH 8 C_TRIG3_UNIT_COUNTER_WIDTH 0 C_TRIG3_UNIT_MATCH_TYPE basic C_TRIG4_UNITS 0 C_TRIG4_TRIGGER_IN_WIDTH 8 C_TRIG4_UNIT_COUNTER_WIDTH 0 C_TRIG4_UNIT_MATCH_TYPE basic C_TRIG5_UNITS 0 C_TRIG5_TRIGGER_IN_WIDTH 8 C_TRIG5_UNIT_COUNTER_WIDTH 0 C_TRIG5_UNIT_MATCH_TYPE basic C_TRIG6_UNITS 0 C_TRIG6_TRIGGER_ IN_WIDTH 8 C_TRIG6_UNIT_COUNTER_WIDTH 0 C_TRIG6_UNIT_MATCH_TYPE basic C_TRIG7_UNITS 0 C_TRIG7_TRIGGER_IN_WIDTH 8 C_TRIG7_UNIT_COUNTER_WIDTH 0 C_TRIG7_UNIT_MATCH_TYPE basic C_TRIG8_UNITS 0 C_TRIG8_TRIGGER_IN_WIDTH 8 C_TRIG8_UNIT_COUNTER_WIDTH 0 C_TRIG8_UNIT_MATCH_TYPE basic C_TRIG9_UNITS 0 C_TRIG9_TRIGGER_IN_WIDTH 8 C_TRIG9_UNIT_COUNTER_WIDTH 0 C_TRIG9_UNIT_MATCH_TYPE basic C_TRIG10_UNITS 0 C_TRIG10_TRIGGER_IN_WIDTH 8 C_TRIG10_UNIT_COUNTER_WIDTH 0 C_TRIG10_UNIT_MATCH_TYPE basic C_TRIG11_UNITS 0 C_ TRIG11_TRIGGER_IN_WIDTH 8 C_TRIG11_UNIT_COUNTER_WIDTH 0 C_TRIG11_UNIT_MATCH_TYPE basic C_TRIG12_UNITS 0 C_TRIG12_TRIGGER_IN_WIDTH 8 C_TRIG12_UNIT_COUNTER_WIDTH 0 C_TRIG12_UNIT_MATCH_TYPE basic C_TRIG13_UNITS 0 C_TRIG13_TRIGGER_IN_WIDTH 8 C_TRIG13_UNIT_COUNTER_WIDTH 0 C_TRIG13_UNIT_MATCH_TYPE basic C_TRIG14_UNITS 0 C_TRIG14_TRIGGER_IN_WIDTH 8 C_TRIG14_UNIT_COUNTER_WIDTH 0 C_TRIG14_UNIT_MATCH_TYPE basic C_TRIG15_UNITS 0 C_TRIG15_TRIGGER_IN_WIDTH 8 C_TRIG15_UNIT_COUNTER_WIDTH 0 C_TRIG15_UNIT_MATCH_T YPE basic IPNAME chipscope_ila ERROR:MDT - chipscope_ila_0 (chipscope_ila) - Generating the Chipscope core : cs_coregen_chipscope_ila_0.... Chipscope Core Generator Error : ChipScope Pro Core Generator Version : 9.1.01i Build : 09101.7.12.910 Reading arguments from file E:/doc/V2P_CD/Reference_Designs/edk_7_1_builds/video_capture_rev_1_1/pal/chip pro_video_capture_rev_1_1/implementation/cs_coregen_chipscope_ila_0.arg Warning: Arguments from file will override command line arguments
Creating EDIF NetlistE:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\p al\chippro_video_capture_rev_1_1/implementation/chipscope_ila_0_wrapper/\cs_c oregen_chipscope_ila_0.edn Component Name: cs_coregen_chipscope_ila_0 Manufacturer ID: 1 Core Type: 2 Core Version: v9.1.1 Device Family: Virtex2P SRL16 Type: SRLC16/E RAM Type: 16384-bit block RAM Clock Edge Used for Sampling: rising edge RPM Usage: enabled Trigger Output Port: disabled Storage Qualification: enabled Data Same as Trigger: true Data port is made up of the following trigger ports: Trigger Port 0 Aggregate Data Width: 8 Data Depth: 512 Enable Gap Recording: false Enable Timestamp Recording: false Number of Trigger Ports: 1 Trigger Port 0 Width:8 Number of Match Units: 1 Match Unit 0 Info: Connection: Trigger Port 0 Type: Basic Match Counter : disabled Trigger Sequencer Type : None External capture : disabled Force RPM Grid Usage: no Resource Utilization Estimate LUT:189 FF:175 BRAM:1 Warning: EDIF Netlist being generated Post Processing EDIF netlist E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chip pro_video_capture_rev_1_1/implementation/chipscope_ila_0_wrapper/\cs_coregen_ chipscope_ila_0.edn Generating constraints file E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chip pro_video_capture_rev_1_1\implementation\chipscope_ila_0_wrapper\cs_coregen_c hipscope_ila_0.ncf Generating CDC file E:\doc\V2P_CD\Reference_Designs\edk_7_1_builds\video_capture_rev_1_1\pal\chip pro_video_capture_rev_1_1\implementation\chipscope_ila_0_wrapper\cs_coregen_c hipscope_ila_0.cdc WARNING: Default charset GBK not supported, using ISO-8859-1 instead Please verify that the MHS Parameters for "chipscope_ila_0" core are valid and the generated Chipscope Core Generator arg file : "implementation/cs_coregen_chipscope_ila_0.arg" is valid ************************************************************* while executing "error " Generating the Chipscope core : cs_coregen_$params(INSTANCE).... Chipscope Core Generator Error : ..." (procedure "::hw_chipscope_ila_v1_01_a::ila_generate" line 117) invoked from within "::hw_chipscope_ila_v1_01_a::ila_generate 40096600" ERROR:MDT - platgen failed with errors! |
