#include<iostream.h> #include<time.h> #include<stdlib.h> #include<string.h> int array[21]; template<class T>//用二分搜索法插入新元素input void insert_new()// { int middle=(begin+end)/2; if(a[0]>=input) { memmove(a+1,a,sizeof(T)*n); a[0]=input; } else { if(a[end]<=input) {
memmove(a+end+2,a+end+1,sizeof(T)*(n-end-1)); a[end+1]=input; } else { if(begin<=end) { if(a[middle]==input||(end-middle)==1||(middle-begin)==1) { memmove(a+middle+1 ,a+middle,sizeof(T)*(n-middle)); a[middle+1]=input; n++; } else { if(a[middle]>input) { insert_new(a,begin,middle-1,n,input); } else { if(a[middle]<input) { insert_new(a,middle+1,end,n,input); } } } } } } }
template<class T>//冒泡法从小到大排序数组 void bubble_sort(T*a,int n) { T mi=0; for(int i=n-1;i>=0;i--) { for(int k=0;k<i;k++) { if(a[k]>a[k+1]) { mi=a[k]; a[k]=a[k+1]; a[k+1]=mi; } } } } inline void arragement(int*a,int n)//输出数组值 { int count=0; for(int i=0;i<n;i++) { cout<<a<<" "; count++; if(count%5==0) { cout<<endl; } } cout<<endl; } void re_rand(int n,int*ch)//产生随机数组 { srand((unsigned)time(0));//以当前时间开始产生随机种子 for(int i=0;i<n;i++) { ch=rand();//产生随机数并用数组ch存储 } } //extern void* memmove(void*,const void*,unsigned int);//函数声明 //void arragement(int*,int); //void re_rand(int,int*); void main() { int input; re_rand(20,array);//产生随机数组 cout<<"Output the random arrag:"<<endl; arragement(array,20);//输出随机生成的数组 bubble_sort(array,20); cout<<"Output the ranked array:"<<endl; arragement(array,20); cout<<"Input an integer:"; cin>>input; insert_new(array,0,19,20,input); cout<<"Output the inserted array:"<<endl; arragement(array,21);
