verilog/////////////////////////////////////////////// // RS232异步数据接收模块 baudClk8x/8,8,n,1 // 2002-2005 /////////////////////////////////////////////// module UartRec( rst, //异步复位 rxd, //串行数据 baudClk8x, //8X波特率时钟 irq, //中断请求 dataOut //数据输出 ); input rst,rxd,baudClk8x; output irq; output[7:0] dataOut; parameter idle_state=0 , verifyStartBit_state=1, startBitOk_state=2, bit0_state=3, bit1_state=4 , bit2_state=5, bit3_state=6 , bit4_state=7, bit5_state=8 , bit6_state=9, bit7_state=10 ; reg [3:0] bitState; //接收状态机 reg [7:0] shifter; //移位寄存器 reg [7:0] dataOut; //输出锁存器 reg [2:0] bitCounter; //采样计数器 reg irq;
always @(posedge rst or posedge baudClk8x) begin if(rst) begin bitState<=4'd0;//idle_state; bitCounter<=3'd0; shifter<=8'd0; end else begin if(bitState==4'd0)//idle_state begin if(!rxd) begin bitState<=bitState+1; bitCounter<=3'd0; end end else if(bitState==4'd1)//verifyStartBit_state: begin if(bitCounter==3'd3) begin if(!rxd) //校验起始位是否依然有效 bitState<=bitState+1;//4'd2 bit 0 state else bitState<=4'd0; //idle_state;
bitCounter<=3'd0; end else bitCounter<=bitCounter+1; end else if(bitState==4'd10)//bit7_state begin if(bitCounter==3'd7) //返回初始状态,不检查停止位 begin bitCounter<=3'd0; bitState<=4'd0; end else bitCounter<=bitCounter+1; end
else //bitState=2~9 8个数据位接收 begin if(bitCounter==3'd7) begin shifter<={rxd,shifter[7:1]}; bitCounter<=3'd0; bitState<=bitState+1; end else bitCounter<=bitCounter+1; end end end
always @(posedge rst or negedge baudClk8x) begin if(rst) begin dataOut<=0; irq<=0; end else if(bitState==4'd10) begin dataOut<=shifter; irq<=1; end else irq<=0;
end endmodule |
