各位大侠!帮我看看锁存器程序.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity latch is
port (d:in std_logic_vector(7 downto 0);
q ut std_logic_vector(7 downto 0);
clk,oe: in std_logic );
end latch;
architecture a of latch is
signal qint: std_logic_vector(7 downto 0);
begin
process(clk,d)
begin
if clk'event and clk='1'then
qint<=d;
end if;
end process;
if oe='0'then q<=qint; --when (oe='0')
else q<='zzzzzzzz';
end a;
提示:error:line21: vhdl syntax error: character literal "z" must be
terminated with an apostrophe
谢谢! |
