各位答人,小弟初学乍练,想求一个计数显示电路(VHDL),键盘接口显示电路(VHDL)。
计数显示电路部分可逆计数电路(10进制)计数最大值256即可,显示电路用三个数码管。最高频率4M;
键盘接口显示电路部分3乘4键盘,0-9和两个功能键(清零,计数)。显示电路三位数码管分别致入。
如果哪位大哥肯帮忙,十分感谢。我的邮箱:BRIGHT_FW@yahoo.com.cn
我做了两个程序,但都是component调用有问题。
计数显示电路:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity countb is
port (cp,ec,a,s,clr:in std_logic;
q ut std_logic_vector(7 downto 0);
bin ut std_logic_vector(3 downto 0);
ec0 ut std_logic;
cy10 ut std_logic
end countb;
architecture example of countb is
signal count_b:std_logic_vector(9 downto 0);
signal p1,p2,rst,dly: std_logic;
begin
process (cp)
begin
if ( rst='1')then
count_b<="0000000000";
elsif (cp'event and cp='1') then
p2<=p1;p1<=a;
dly<=count_b(3);
if (ec='1') then
count_b<=count_b+1; --一时加计?
else
count_b<=count_b-1;
end if;
end if;
end process;
rst<='1'when count_b=10 or clr='1' else
'0';
cy10<=not count_b(3) and dly;
bin<=(count_b(3)&count_b(2)&count_b(1)&count_b(0)) when s='1'else
"0000";
ec0<=p1 and not p2;
q<=count_b(7)&count_b(6)&count_b(5)&count_b(4)&count_b(3)&count_b(2)&count_b(1)&count_b(0);
end example;
library ieee;
use ieee.std_logic_arith.all;
entity count_dsp is
port (cp,clear:in std_logic;
segout ut std_logic_vector(7 downto 0);
selout ut std_logic_vector(5 downto 0);
numout ut std_logic_vector(3 downto 0) );
end count_dsp;
architecture a of count_dsp is
component countb
port(
cp :in std_logic;
s :in std_logic;
a :in std_logic;
clr :in std_logic;
ec :in std_logic;
ec0 ut std_logic;
cy10 :out std_logic
end component;
signal bin : std_logic_vector(3 downto 0);
signal dbs : std_logic_vector(5 downto 0);
signal dbm : std_logic_vector(5 downto 0);
signal dbh : std_logic_vector(5 downto 0);
signal ec0 : std_logic;
signal enb : std_logic_vector(2 downto 0);
signal bcd : std_logic_vector(3 downto 0);
signal clr : std_logic;
signal cys,cym,cyh : std_logic;
signal s : std_logic_vector(2 downto 0);
signal num : std_logic_vector(3 downto 0);
signal seg : std_logic_vector(6 downto 0);
signal sel : std_logic_vector(5 downto 0);
begin
connection:block
begin
U0:countb port map(cp,dbs,enb(0),clr,ec0,cys);
U1:countb port map(cp,dbm,enb(1),clr,cys,cym);
U2:countb port map(cp,dbh,enb(2),clr,cym,cyh);
clr<=clear;
selout<=sel;
segout(6 downto 0)<=seg;
segout(7)<='0';
numout<=num;
end block connection;
free_counter:block
signal q : std_logic_vector(24 downto 0);
begin
process(cp)
begin
if cp'event and cp='1' then
q<=q+1;
end if;
end process;
s<=q(15 downto 13);
sel<= "111110" when s=0 else
"111101" when s=1 else
"111011" when s=2 else
"110111" when s=3 else
"101111" when s=4 else
"011111" when s=5 else
"111111";
enb<= "001" when (s=0 or s=1) else
"010" when (s=2 or s=3) else
"100" when (s=4 or s=5) else
"000";
bin<= dbs when enb="001" else
dbm when enb="010" else
dbh when enb="100" else
"0000";
end block free_counter;
binary_bcd:block
begin
bcd<="0000" when bin=0 else
"0001" when bin=1 else
"0010" when bin=2 else
"0011" when bin=3 else
"0100" when bin=4 else
"0101" when bin=5 else
"0110" when bin=6 else
"0111" when bin=7 else
"1000" when bin=8 else
"1001" when bin=9 else
"1111";
end block binary_bcd;
select_bcd:block
begin
num<= bcd;
end block select_bcd;
sevent_segment:block
begin
seg<= "0111111"when num=0 else
"0000110"when num=1 else
"1011011"when num=2 else
"1001111"when num=3 else
"1100110"when num=4 else
"1101101"when num=5 else
"1111101"when num=6 else
"0000111"when num=7 else
"1111111"when num=8 else
"1101111"when num=9 else
"0000000" ;
end block sevent_segment;
end a;
可以给我指点一下,或是给我一个例程都十分感谢。[em17] |
