串行A/D转换器TLC2543 C51接口函数
code unsigned int ad_lst[16]={32768,16384,8192,4096,2048,1024,512,256,128,64,32,16,8,4,2,1}; //===================================== //===========A/D转换函数================ //===================================== unsigned int adzh(unsigned char prot) { unsigned char i; unsigned char ad_reg=prot; //通道号 unsigned int ad16=0; CS=1; //TLC2543片选 CS=0; //片选使能 //设置A/D 16位 通道0,单极性信号转换,高位在先 for (i=0;i<8;i++) { ACC=ad_reg; CLOCK=0; CLOCK=1; //CP上升沿 if (D_OUT) { ad16=ad16+ad_lst; D_IN=ACC^7; //写入 } else { ad16=ad16+0; D_IN=ACC^7; //写入 } ad_reg=(ad_reg<<1); } for (i=8;i<16;i++) { CLOCK=0; CLOCK=1; if (D_OUT) { ad16=ad16+ad_lst; } ad16=ad16+0; D_IN=0; } CS=1; //片选禁止! return (ad16>>4); } 上面的程序我已经调试通过的,供网有参考! 误见笑!
