请教关于GR2287
一般来说,sys-test 可以过就行.pre-test的功能很少有人会用到的.
aaa
请教关于GR2287
我这边有台机器是2287-i, 我在做自检时,Peripheral System tests
和Instrument System tests全都PASS。但High Speed System Tests偶尔可以全PASS.
但经常会出现以下问题,接下去pin卡的测试也全都FAIL,各路好手请给点建议!
非常感谢!!!
228DIA:2287est00.obc 03-JUN-04  15:21:46
*** High Speed Subsystem Monitor Started Thu Jun 03 15:31:04 2004 ***
FAILED - Result address test, Result memory data is incorrect.
FAILED - Pin board #1 result memory.
FAILED - Pin board #1 result memory.。。。。
Fail    :HSC
        * Actual: 0xffffffff
        * Expected: 0
        * Address: 0x100
FAILED - RESULT MEMORY should have read a zero!
        * Expected: 0
        * Address: 0x101
        * Expected: 0
        * Address: 0x102
        * Expected: 0
        * Address: 0x103
Do It easy!
你进diagnose模式做High Speed System Tests自检,将自检报告发给我看看.
nicholas_lp@163.com
aaa
