[求助]如何进行电源分割
[求助]如何进行电源分割
我是第一次用orcad layout画四层板,由几根线不能通过顶层和底层走线,于是我用铺铜的方式在电源层走线,但是电源层本身已经几个电源了,请问我该怎么办?
我是一只迷茫的羔羊。
1.From the Window menu, choose Database Spreadsheets. Select Nets in   the Select Data Window dialog box and choose the OK button.
2.Select the nets you want to assign to the plane.
3.From the right mouse button pop-up menu, choose Modify. The Edit Net dialog box displays.
4.Choose Net Layers to display the Layers Enabled for Routing dialog box, then select GND or POWER in Plane Layers to assign the nets to the appropriate plane.
5.Choose the OK buton to close the Layers Enabled for Routing dialog box, then choose the OK button to close the Edit Net dialog box.
6.To split the plane, place a DETAIL obstacle on the plane layer. This divides the plane and gives it the desired width.
7.When you place the parts, make sure the parts with POWER and GND nets are placed on separate sides of the board. When you run a dispersion route, it places vias to the plane layer. All nets assigned to the plane will thermal to the plane regardless of which side of the plane they are on.
8.You should carefully check thermals. One way to make checking thermals easier is to change the color of the nets in the Nets spreadsheet to unique colors. This is the color that the thermal relief uses.
我是主持人,煸情功夫一流。我是工程师,刻苦学习一生。我是海王星,透明蓝色一体。因为有了你,我就一通百通。
