数码管驱动的问题
数码管驱动的问题
[em27][em27][em27][em27][em27][em27][em27][em27][em27] 我用的是JK3的片子想驱动共阳数码管,D口加一级8550驱动,B口做字符译码,大概程序如下,可是数码管全亮,问题到现在还没有找出来。请大虾帮忙。 #include /* for EnableInterrupts macro */ #include /* include peripheral declarations */ #define Enable EnableInterrupts #define Disable DisableInterrupts unsigned int RT; unsigned int addr; unsigned int value; unsigned int Code[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; void sysinit(void) { Disable; CONFIG1=0; DDRB=0xFF; PTB=0x00; DDRD=0xF0; PTD=0x00; PDCR=0xFF; ADICLK=0x70; ADSCR=0x68; } void delay(void) { unsigned int i; for(i=0;i<1000;i++); } void interrupt INT_ADC A() { RT=ADR; } void Sendled(addr,value) { switch(addr) { case 1: { DDRD=0X80; DDRB=Code[value]; };break; case 2: { DDRD=0X40; DDRB=Code[value]; };break; case 3: { DDRD=0X20; DDRB=Code[value]; };break; case 4: { DDRD=0X10; DDRB=Code[value]; };break; } } void Displayled(void) { Sendled(1,RT/1000); delay(); Sendled(2,RT/100); delay(); Sendled(3,RT/10); delay(); Sendled(4,RT%10); delay(); } void main(void) { sysinit(); delay(); Enable; while(1) { Displayled(); __RESET_WATCHDOG(); }; }
请问你用的是多少频率的晶振,如果是以内部总线1M频率算,你的延时才1~2ms,当然数码管是全亮的.
走向MCU开发的乐趣!
谢谢!我用的是8MHz晶振,问题已经找到了,我开的AD中断,把AD中断关闭就行了
