[讨论]关于电容器耐大纹波电流问题
请斑竹给予支持!多谢!
欢迎指教 随风!
LP Series 基板自立型大电容品(低中压品)
Features
■  Directly mountable on printed circuit board without holders.
■  Smaller low profile sizes than ordinary capacitors.
■  Terminal spacing fixed at 10mm for PC board plug in.
■  Aluminum case designed explosion-proof vent.
Specifications
Voltage Range 10~100V 160~450V
Capacitance Range 470~68000μF 47~2700μF
Temperature Range -40~+85℃ -25~+85℃
Capacitance Tolerance -20~+20% (at 20℃,120Hz)
Leakage Current I≤0.02CV (μA)   (After 5 minutes)
Dissipation Factor
  (tanδ) Less than the value under table (at 20℃, 120Hz)
315~450 160V~250 80~100 50~63 25~35 10~16
47~330         0.15 0.20
470~3300 0.25 0.20 0.20 0.20 0.15 0.20
4700~6800 0.35 0.30 0.30 0.25
10000~22000 0.40 0.35 0.30
27000~47000 0.45 0.40 0.35
56000~68000 0.50 0.45
Stability at
  Low Temperature
Impedance ratio at 120Hz:
Z-25℃/Z20℃:   3 max.
  Z-40℃/Z20℃:  12 max.
Load Life The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied for 2000 hours at 85℃.
Capacitance Change Within±20% of initial value.
D.F.(tanδ) 200% or less of initial specified value.
Leakage Current Initial specified value or less.
Shelf Life
At 85℃ no voltage applied after 500 hours the capacitors shall meet the following limite.
Capacitance Change
≤ ±20%  of initial value.
Dissipation Factor
≤  150%  of initial specified value.
Leakage Current
≤  200%  of initial specified value.
Terminal Type(Case Vent)
P.C.B.Terminal(Snap-in)
Ambient temp. Multiplying factor
45℃ & under 1.55
60℃ 1.30
70℃ 1.20
85℃ 1.00
Frequency Multiplying factor
10~35v 50~100v 160~250v 315~450v
60Hz 0.90 0.90 0.80 0.90
120Hz 1.00 1.00 1.00 1.00
1kHz 1.05 1.15 1.35 1.30
10kHz 1.10 1.20 1.45 1.40
100kHz 1.10 1.20 1.50 1.45
Case Size Table & Ripple Current
WV Cap.
[μF] Case Size
D×l[mm] Ripple Current
[μA]
rms max. (120Hz/85℃) WV Cap.
[μF] Case Size
[μA
]rms max. (120Hz/85℃)
16V 4700 22×21 2.00 25v 39000 35×47 5.92
6800 22×26 2.37 47000 35×52 6.34
8200 22×26 2.42 35v 2200 22×26 6.82
10000 22×31 2.55 3300 22×26 2.05
25×26
12000 22×31 2.86 3900 22×31 2.20
25×26
15000 22×36 3.28 4700 22×31 2.24
25×31 25×26
18000 22×41 3.62 6800 22×36 2.55
25×31 25×31
22000 22×46 4.01 10000 22×46 3.00
25×36 25×41
30×31
30×31
27000 25×46 6.31 12000 25×46 3.40
30×36
30×36 35×42
33000 25×51 6.84 15000 5×51 3.92
30×41 30×41
35×32
35×32
39000 30×46 6.94 18000 30×46 4.35
35×36 35×37
47000 30×51 7.47 22000 30×51 4.54
35×41 35×42
56000 35×46 8.73 27000 35×47 4.82
68000 35×51 9.05 33000 35×52 5.3
25V 4700 22×26 2.2 50v 1500 22×26 1.2
5600 22×31 2.32 2200 22×26 1.7
6800 22×31 2.44 2700 22×31 1.93
25×26
8200 22×31 2.54 3300 22×31 2.2
25×26 25×26
10000 22×36 2.86 4700 22×36 2.4
25×31 25×31
30×26
30×26
12000 22×41 3.22 5600 22×41 2.55
25×36 25×36
31×31
30×31
15000 22×51 3.66 6800 22×51 2.70
25×41
25×41
30×31 30×31
18000 25×46 4.01 8200 25×46 2.90
30×36 30×36
22000 25×51 4.50 10000 25×51 3.30
30×41
30×41 35×32
27000 30×46 4.98 12000 30×46 3.42
35×36 35×37
33000 30×51 5.20 15000 30×51 3.92
35×42
35×42 18000 35×47 4.43
50V 22000 35×52 4.88 80V
6800 30×51 3.48
35×42
63V 1000 22×26 1.32 8200 35×52 4.10
15000 22×26 1.40 100V 470 22×21 1.12
2200 22×31 2.1 680 22×26 1.28
25×26
2700 22×36 2.35 1000 22×31 1.35
25×31 25×26
3300 22×41 2.6 1200 22×36 1.45
25×31
25×31
30×26
3900 22×46 2.68 1500 22×41 1.54
25×36 25×31
30×31 30×26
4700 22×51
2.74
1800 22×46 1.83
25×41
25×36
35×27
30×31
35×27
5600 25×46 3.22 2200 22×51 2.20
30×36 25×41
35×32 30×31
6800 25×51 3.60 2700 25×46 2.64
31×41
30×36
35×32
8200 30×46 3.70 3300 25×51 2.85
35×37 30×41
10000 35×42 3.98 3900 30×46 2.99
35×37
12000 35×52 4.20 4700 30×51 3.10
35×42
80V
680 22×21 1.12 5600 35×47 3.10
1000 22×26 1.35 6800 35×52 3.42
1500 22×31 1.47  180 22×21 0.94
25×26
1800 22×36 1.52 270 22×26 1.13
25×31
2200 22×41 2.1 330 22×26 1.20
25×31
30×26
2700 22×46 2.3 390 22×31 1.52
25×36
25×36
30×31
3300 22×51 2.7 470 22×31 1.70
25×41
25×26
30×31
3900 25×46 2.84 560 22×36 1.90
25×31
31×36
30×26
4700 25×51 3.00 680 22×41 1.92
25×36
30×41
30×26
5600 30×46 3.15 820 22×46 2.10
25×36
30×31
1000 25×46 2.50
30×36
35×37
35×32
1200 25×51 2.71
160 1200 30×36 3.08 250 470 25×41 1.60
35×32 30×31
1500 30×46 3.30 560 25×46 1.80
35×37 30×36
1800 30×51 3.59 35×27
35×42 680 25×51 2.00
2200 35×47 3.88 30×41
2700 35×52 3.97 35×32
200 150 22×21 0.80 820 30×46 2.20
220 22×26 0.95 35×37
270 22×26 1.11 1000 30×51 2.85
330 22×31 1.25 35×42
25×26 1200 35×47 2.94
470 22×36 1.72 1500 35×52 3.02
25×31 350 68 22×21 0.44
30×26 82 22×26 0.51
560 22×41 1.92 100 22×26 0.65
25×36 25×21
30×26 120 22×31 0.71
680 22×46 1.95 25×26
25×36 30×21
30×31 150 22×36 0.82
820 25×46 2.30 25×31
30×36 30×26
35×27 35×22
1000 25×52 2.80 180 22×41 0.98
30×42 25×36
35×32 30×27
1200 30×46 3.27 35×22
35×37 220 22×46 1.05
1500 30×51 3.50 25×41
35×42 30×31
1800 35×47 3.79 35×27
2200 35×52 4.32 270 25×46 1.34
250 120 22×21 0.71 30×36
150 22×26 0.82 35×27
180 22×26 0.94 330 25×51 1.60
220 22×31 1.00 30×41
25×26 35×32
270 22×31 1.19 390 30×46 1.83
25×26 35×37
330 22×36 1.28 470 30×51 2.00
25×31 35×42
30×26 560 35×47 2.20
390 22×41 1.43 680 35×52 2.42
25×36 400 47 22×21 0.35
30×26 68 22×26 0.43
470 22×46 1.60 82 22×26 0.67
400 100 22×31 0.70
25×26
120 22×36 0.75
25×31
150 22×41 0.88
25×31
30×26
180 22×46 0.93
25×36
30×31
220 22×51 1.10
25×41
30×31
270 25×46 1.34
30×36
35×32
330 30×41 0.50
35×37
390 30×36 1.63
35×42
470 35×47 1.85
560 35×52 1.97
450 47 22×26 0.30
100 22×36 0.68
25×31
150 22×51 0.90
25×41
30×31
220 25×51 1.20
35×37
330 35×47 1.60
谢谢斑竹!
我要的不是哪一个规格产品的最大耐纹波电流能力。我想请教各位,对于SNAP-IN产品,请引出端子能承受多大电流。
另外,请问1平方毫米铝大小的铝线最大能承受多大电流?
谢谢!!!!!!!!!!!!
欢迎指教 随风!
[讨论]关于电容器耐大纹波电流问题
各位大侠:
小生这边有理了!
想请教各位,铝电解电容器都规定了其使用的最大纹波电流不能超过各厂商样本规定的值。这很重要!!
但譬如SCREW产品规定了其最大的耐纹波电流不能超过30A或者50、60A(根据不同的螺栓尺寸),而对于SNAP-IN产品呢?各创伤均未有相关规定,不知哪位手上有相关资料,可否传阅?
多谢!!!!!!!!
[em02]
欢迎指教 随风!
这个你可能要问一下专业的制造商,或许他们知道,或者上他们的网站download他们的datasheet.
