请帮我看看这个程序怎么REJECT 语句发生编译错误啊
![Rank: 2](images/default/star_level2.gif)
错误是:identifier "REJECT" has not been declared;
怎么去声名?谢谢!
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH;
ENTITY dff_first IS
PORT ( clk : IN STD_LOGIC;
q : OUT STD_LOGIC);
END dff_first;
ARCHITECTURE dff1 OF dff_first IS
BEGIN
PROCESS (clk)
VARIABLE tmp:STD_LOGIC:='0';
BEGIN
IF clk='1' AND clk'EVENT THEN
--AND clk'LAST_VALUE = '0' THEN
q<=NOT tmp ;
tmp:=NOT tmp;
END IF;
END PROCESS;
END dff1;
ENTITY muxdff IS
PORT (clk : IN STD_LOGIC;
cp : OUT STD_LOGIC);
END muxdff;
ARCHITECTURE mux_dff1 OF muxdff IS
COMPONENT dff_first
PORT(clk : IN STD_LOGIC;
q : OUT STD_LOGIC);
END COMPONENT;
SIGNAL u: STD_LOGIC_VECTOR(0 TO 2);
SIGNAL sig_det : STD_LOGIC;
BEGIN
dff_1: dff_first PORT MAP (clk,u(0));
g1: FOR i IN 1 TO 2 GENERATE
dff_1:dff_first PORT MAP (u(i-1),u(i));
END GENERATE;
sig_det <= clk AND u(0) AND u(1) AND u(2);
cp <= REJECT 20 ns INERTAL sig_det AFTER 2 ns;
END mux_dff1; |
