Ê×Ò³ | ÐÂÎÅ | ÐÂÆ· | ÎÄ¿â | ·½°¸ | ÊÓÆµ | ÏÂÔØ | ÉÌ³Ç | ¿ª·¢°å | Êý¾ÝÖÐÐÄ | ×ù̸аæ | Åàѵ | ¹¤¾ß | ²©¿Í | ÂÛ̳ | °Ù¿Æ | GEC | »î¶¯ | Ö÷ÌâÔ | µç×ÓÕ¹
·µ»ØÁÐ±í »Ø¸´ ·¢Ìû
ΪʲôλѰַµÄ±äÁ¿£¬Õâô¸³Öµ²»ÐУ¿£¿
unsigned char bdata Iostate;
unsigned char bdata bvar0;
sbit MsFlag = bvar0^5;    //0-ON , 1-OFF 5ºÁÃ뷭ת±êÖ¾
main£¨£©
unsigned char bdata *pp;
pp = &Iostate;
  (*pp)^2=MsFlag;       //for syntax check
      ÎªÊ²Ã´Õâôд£¬  (*pp)^2=MsFlag;    ÕâÐлá±àÒë´íÎó£¨ TOUCH.C(938): error C141: syntax error near '='£©?
      ÎÒÕâôд£¬ÓÐʲô´íÎóÄØ£¿£¡
(*pp)^2=MsFlag;Õâ¸ö²»·ûºÏCµÄÓï·¨£¬¼´Ê¹ÔÚVC±àÒëÆ÷ÀïÃæÒ²Í¨²»¹ýµÄ¡£
Äܲ»ÄÜ˵µÃÃ÷°×Ò»µã£¬¶ÔÓÚλѰַµÄ±äÁ¿£¬Ó¦¸ÃÈçºÎ¸³Öµ£¿
ÎÒ¸Ä³É P0^2= MsFlag;  ±àÒë¶¼»á³ö´í¡£
P0·ÖÃ÷ÊÇ¿ÉÒÔλѰַµÄ°¡£¿£¿£¿  ÎÒ¸ÃÔõôÀí½â£¿Çë½âÊÍ£¬Íò·Ö¸Ðл
/*** PTA - Port A Data Register ***/
typedef union {
  byte Byte;
  struct {
    byte PTA0    :1;           /* Port A Data Bit 0 */
    byte PTA1    :1;           /* Port A Data Bit 1 */
    byte PTA2    :1;           /* Port A Data Bit 2 */
    byte PTA3    :1;           /* Port A Data Bit 3 */
    byte PTA4    :1;           /* Port A Data Bit 4 */
    byte PTA5    :1;           /* Port A Data Bit 5 */
    byte PTA6    :1;           /* Port A Data Bit 6 */
    byte PTA7    :1;           /* Port A Data Bit 7 */
  } Bits;
  struct {
    byte PTA     :8;
  } MergedBits;
} PTASTR;
extern volatile PTASTR _PTA @0x00000000;
#define PTA _PTA.Byte
#define PTA_PTA0 _PTA.Bits.PTA0
#define PTA_PTA1 _PTA.Bits.PTA1
#define PTA_PTA2 _PTA.Bits.PTA2
#define PTA_PTA3 _PTA.Bits.PTA3
#define PTA_PTA4 _PTA.Bits.PTA4
#define PTA_PTA5 _PTA.Bits.PTA5
#define PTA_PTA6 _PTA.Bits.PTA6
#define PTA_PTA7 _PTA.Bits.PTA7
#define PTA_PTA _PTA.MergedBits.PTA
¿ÉÒÔ¿´Ò»ÏÂÓÃCW×Ô¶¯Éú³ÉµÄ¶¨Òå·½·¨¡£
¼ÙÉèPTA0ÖÃλ¿ÉÒÔÕâÑùд
PTA_PTA0=1;
codewarriorµÄÿ¸öMCU×Ô¶¯Éú³ÉµÄÍ·Îļþ¶¼ÓÐbit±äÁ¿µÄ±íʾ·½·¨.¿ÉÒÔ²ÎÕÕ,
¸ù¾Ý±àÒëÆ÷µÄ²»Í¬,bitѰַµÄ±íʾ·½·¨Ò²²»Í¬.ÄãдµÄÄÇÖÐÔÚkeil±àÒëÆ÷ÊÇÕâÖÖ±íʾ·½Ê½Èç
sbit p10=P1^0;
µ«ÊÇÄãÕâ¾ä
(*pp)^2=MsFlag;
ÔÚÄÄÀïÓ¦¸Ã¶¼ÊÇ´íÎóµÄ.ÒòΪÄã(*pp)^2±íʾµÄÊÇÒì»ò.
Á¢Ö¾×ö¸öרҵµÄ¹¤³Ìʦ
·µ»ØÁбí
