奇怪!!!!CAN只能收不能发送?
奇怪!!!!CAN只能收不能发送?
我使用的是HCS12D64,在使用CAN时,CAN只能接收不能发送,发送时测量CANL和地、CANH和地之间的信号,发现信号不对,一旦发送一次,这种不对的信号一直存在,为什么呢?程序如下:
初始化:
 void initMSCAN(void)
//MSCAN初始化
CAN0CTL0_INITRQ = 1;
  while(CAN0CTL1_INITAK!=1);
   CAN0CTL1_CANE = 1;
  // MODRR=02;
  MODRR_MODRR0=0;
  MODRR_MODRR1=1;
   CAN0CTL1_CLKSRC = 0; /* 选择晶振频率 */
   #ifdef LoopMode
  CAN0CTL1_LOOPB = 1;
  #else
  CAN0CTL1_LOOPB = 0;
  #endif
  CAN0CTL1_LISTEN = 0;
  /* 用4M晶振125 kb rate */
   CAN0BTR0=0x01;
   CAN0BTR1=0x1C;
   CAN0IDAC  = 0; /* two 32bit acceptance filter*/
  /*下面仅配置为接受ID=02的扩展贞格式,此时Hit 0 命中,但对于ID=0的标准贞也接受,此时Hit 1命中*/
  CAN0IDAR0 =0x00;
  CAN0IDAR1 =0x00;
  CAN0IDAR2 =0x00;
  CAN0IDAR3 =0x04; //接受ID=2
  CAN0IDMR0 = 0x00;
  CAN0IDMR1 =0x18;//屏蔽SRR和IDE
   CAN0IDMR2 = 0x00;
   CAN0IDMR3 = 0x03;//屏蔽RTR
  CAN0IDAR4 =0x00;//注意:如果标准贞ID设为1000,则也可接收到,因为1000已超出11位,所以此时的ID也为0
  CAN0IDAR5 =0x00;
  CAN0IDAR6 =0x00;
   CAN0IDAR7 =0x00;
  CAN0IDMR4 = 0x00;
   CAN0IDMR5 = 0x00;
   CAN0IDMR6 = 0x00;
   CAN0IDMR7 = 0x00;
   CAN0CTL0_INITRQ = 0;
  while(CAN0CTL1_INITAK!=0);
   while ((CAN0CTL1&0x01) != 0){}; /* Wait for Normal Mode */
  CAN0RIER_RXFIE = 1; /* 接收中断使能,禁止发送中断 */
发送函数
void CAN_Transmit(uchar id)
//CAN发送
  unsigned char mask;
  mask = CAN0TFLG;
   CAN0TBSEL= mask;
   CAN0TXIDR0  = 0xff;
   CAN0TXIDR1  = 0xff;  //扩展桢
   CAN0TXIDR2  = 0xff;
   CAN0TXIDR3  = 1; //发送ID=2
   CAN0TXDSR0  = 200;
   CAN0TXDSR1  = 212;
   CAN0TXDSR2  = 111;
   CAN0TXDSR3  = 23;
   CAN0TXDSR4  = 89;
   CAN0TXDSR5 = 155;
   CAN0TXDSR6  = 199;
   CAN0TXDSR7  = 0;
   CAN0TXDLR  = 0x08;
   CAN0TXTBPR  = 0x00;
   CAN0TFLG = mask;
