中断问题
中断问题
中断问题
我在nios2中写了一个按键的中断程序,可就是进不了中断
下面就是我的程序:
#include "system.h"
#include "altera_avalon_pio_regs.h"
#include "alt_types.h"
#include "altera_avalon_uart_regs.h"
#include "sys/alt_irq.h"
volatile int edge_capture;
static void handle_key_interrupt(void* context,alt_u32 id)
// int* edge_capture_ptr=(int*)context;
// IOWR_ALTERA_AVALON_PIO_EDGE_CAP(KEY_PIO_BASE);
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(KEY_PIO_BASE, 0xff);
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0x55);
static void init_key_pio()
  /* Recast the edge_capture pointer to match the alt_irq_register() function
   * prototype. */
  void* edge_capture_ptr = (void*) &edge_capture;
  /* Enable all key interrupts. */
  /* Reset the edge capture register. */
  IOWR_ALTERA_AVALON_PIO_EDGE_CAP(KEY_PIO_BASE, 0x0);
  /* Register the interrupt handler. */
  alt_irq_register( KEY_PIO_IRQ, edge_capture_ptr, handle_key_interrupt );
int main (void) __attribute__ ((weak, alias ("alt_main")));
int alt_main (void)
    volatile int i;
    i=0;
//   alt_u8 led=0x01;
//    alt_u8 key;
#ifdef KEY_PIO_BASE
  init_key_pio();
#endif
    i=alt_irq_enabled();
    IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0xf0);
  while (1)
  return 0;
