我使用NE64,调试程序时,从串口输出以下信息:
EtherOpen(start...) mdcsel= 05; bufmap= 04; maxfl= 0600 MAC ADDR 000B 06E3 407B EtherType = 00; Programmable etype = 0000 rxmode= 00 netctl 02 Full-Douplex mode EtherOpen(end)
--MII write-- --MII read--DATA= 7F00
--MII read--DATA= 2100
--MII write-- --MII read--DATA= 7F00 Initializing ARP.......... Initializing UDP.... UDP Initialized Initializing UDP demo client Searching for free UDP socket... Free socket found >>>>>>>>>Entering to MAIN LOOP>>>>>>>>>
***EPHY_ISR
--MII read--DATA= 7F10
PHY Interrupt: ================= ###PHY_R16_LKC=LINK CHANGE### --MII read--DATA= 2100
@@@@LINK IS UP@@@@
================= ***EPHYisr_ENDSending UDP... Trying to find MAC address from ARP Cache Need to send ARP Request to local network.. --TXstart-- ***EMAC_TX_COMPLETE_ISR***isr_END-TXEND-ARP Request Sent ARP or lower layer not ready, try again
然后就一直循环输出
Sending UDP... Trying to find MAC address from ARP Cache Address In Cache Address in cache but unresolved ARP or lower layer not ready, try again
不知道什么原因?高手给提示一下 |
