void main(void) { /* Write your local variable definition here */ /*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/ PE_low_level_init(); /*** End of Processor Expert internal initialization. ***/ for(;;){ err = AS1_RecvChar(&ch); AS1_SendChar(0x55); } 这是用PE生成的,仅供参考 |
