Error:L1004:Segment start Address expeted是怎么回事?
用CW5。0,芯片选的mc9s08qg4,编译能过,make的时候出现
Error1004:Segment start Address expeted,指向project.prm中的
    Z_RAM                    =  READ_WRITE   0x0060 TO 0x00FF;行,project.prm是系统自己生成的啊?问题可能出在收码地方呢?project.prm文件如下:
/* This is a linker parameter file for the QG4 */
NAMES END /* CodeWarrior will pass all the needed files to the linker by command line. But here you may add your own files too. */
SEGMENTS /* Here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. */
    ROM                      =  READ_ONLY    0xF000 TO 0xFBFF;
    FLASH_PRO_ROM            =  READ_ONLY
    RAM                      =  READ_WRITE   0x0100 TO 0x015F;
    ROM1                     =  READ_ONLY    0xFFC0 TO 0xFFCF;
END
PLACEMENT /* Here all predefined and user segments are placed into the SEGMENTS defined above. */
    FAR_RAM                             INTO  RAM;
    DEFAULT_ROM, ROM_VAR, STRINGS       INTO  ROM; /* ROM1 In case you want to use ROM1 as well, be sure the option -OnB=b is passed to the compiler. */
    _DATA_ZEROPAGE, MY_ZEROPAGE, DEFAULT_RAM         INTO  Z_RAM;
END
STACKSIZE 0x30
VECTOR 0 _Startup /* Reset vector: this is the default entry point for an application. */
有志青年!
END
你的prm文件中间出现的红色标注的应该不是默认生成的
哦,非常感谢!
有志青年!
