我设置的时间周期是1ms,Timer是MTIMmod;Method是Enable,Disable,Reset,GetTimeUS,GetTimeMS。
void main(void) { /*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/ PE_low_level_init(); /*** End of Processor Expert internal initialization. ***/
/* Write your code here */
unsigned int i, time; int one_loop_us; FC161_Reset();
for( i=0; i<600; ++i ); if( FC161_GetTimeUS( &time )==ERR_OK ) /*老是停在这这里面出不来,究竟什么原因,怎么解决*/
{ one_loop_us = time ;
} /*** Processor Expert end of main routine. DON'T MODIFY THIS CODE!!! ***/ for(;;){} /*** Processor Expert end of main routine. DON'T WRITE CODE BELOW!!! ***/ } /*** End of main routine. DO NOT MODIFY THIS TEXT!!! ***/
