有没有人能帮忙解释一下上面的现象.
因为相同的函数.在codewarrior for hc08中可以编译没有警告.
但是在codewarrior for hcs16中却会出现
sp debug info incorrect because of optimization or inline assembler
The compiler investigates the generated code to detect the current SP value for every instruction. During this process, he detects that two different control flows generate different SP values for a single instruction.
This situation may arise because of different situations:
-inline assembler
In inline assembler code, it is legal to have this situation as long
as the stack is correct at the end of the inline assembler block.
-optimization
Especially because of the common code optimization -Of/-Onfx there are situations where this occurs in correct code.
It is impossible to generate correct debug info for this optimization in some cases.
The debugger may show local variables and the call chain incorrect for some parts in a function, for which this message occurs. But this message does not mean that the code generated is wrong in any sense.
Previous versions of the compiler did generate this warning in other situations, for which this version generates correct debug info.
Example (for C code):
void f(int);
void g(void);
void h(void);
void main(void) {
f(1); f(2); f(3);
h();
f(1); f(2); f(3);
g();
f(1); f(2);
The compiler first detects that "f(1); f(2); f(3);" occurs twice and puts this code separately.
The two code patters are replaced by a JSR to the new code.
This situation can be thought as the following non C pseudo code (C does not support local functions):
void main(void) {
void tmp0(void) {
f(1); f(2); f(3);
tmp0();
h();
tmp0();
g();
f(1); f(2);
In a next step, the compiler detects that the code "f(1); f(2);" does also occur twice. So
he generates a second internal function.
void main(void) {
void tmp1(void) {
f(1); f(2);
void tmp0(void) {
tmp1(); f(3);
tmp0();
h();
tmp0();
g();
tmp1();
Now the new code of the function tmp1 (actually tmp1 is not really a function, it is a part of main!) is called once directly from main and once indirectly by using tmp0. This two call chains now use a different amount of stack and the message
"C12056: SP debug info incorrect because of optimization or inline assembler"
is issued.
Example (for C inline assembler code)
void fun(long a, long b, int i);
#pragma NO_EXIT
void main1(void) { /* warning for debug info */
asm {
LDY #4
CLRA
CLRB
L0:
PSHD
DBNE Y, L0
JSR fun ; calls f with a == b == i== 0
LEAS 8,SP
RTS
The loop in main1 is looping 4 times and every time two bytes are pushed on the stack.
This loop let the compiler issue this message because at L0 different SP values occur at different times.
To avoid the inconveniences of such debug info, the same code could be written this way:
void main2(void) { /* debug info is OK */
asm {
CLRA
CLRB
PSHD
PSHD
PSHD
PSHD
LEAS 8,SP
RTS
Tips:
To debug try to switch the common code optimization off with -onf.
For inline assembler avoid this situation.
