请来查一下,错在哪儿?关键词:verilog 滤波
module phaphb1(seg , pha , phb , clock);                //定义模块结构
  output [7:0] seg;                                        //定义数码管段输出引脚
  input clock;                                             //定义输入时钟引脚
  input pha,phb;                                        //定义输入相位
  reg [3:0] sl_reg;                                        //定义数码管选择输出寄存器
  reg [1:0] prestate;
   reg [3:0] disp_dat;                                //定义显示数据寄存器
  reg [5:0] count;                                        //定义计数器寄存器
  reg [7:0] countPos;
   reg [1:0] nvbocnt;
   reg phabk,phbbk;
   reg phaa,phbb;
   reg [1:0] ph;
   reg bit_nb;
always @(pha or phb)
begin
        phaa=pha;
        phbb=phb;
end
always @(posedge clock)
begin
        if(phaa==phabk && phbb==phbbk)
                nvbocnt = nvbocnt + 1;
        else
                phabk=phaa;
                phbbk=phbb;
                nvbocnt = 0;
        if(nvbocnt > 2)
        begin
                ph[0]=phaa;
                ph[1]=phbb;
                nvbocnt=0;
        end
end
always @(ph)
begin
        case(ph)
                2'b00:
                        begin
                                case(prestate)
                                        2'h3: countPos = countPos + 1;
                                        2'h1: countPos = countPos - 1;
                                endcase
                                prestate = 0;
                        end
                2'b10:
                        begin
                                case(prestate)
                                        2'h0: countPos = countPos + 1;
                                        2'h2: countPos = countPos - 1;
                                endcase
                                prestate = 1;
                        end
                2'b11:
                        begin
                                case(prestate)
                                        2'h1: countPos = countPos + 1;
                                        2'h3: countPos = countPos - 1;
                                endcase
                                prestate = 1;
                        end
                2'b01:
                        begin
                                case(prestate)
                                        2'h2: countPos = countPos + 1;
                                        2'h0: countPos = countPos - 1;
                                endcase
                                prestate = 3;
                        end
        endcase
end
always @(posedge clock)                                                        //定义clock信号下降沿触发
begin
        count=count+1;        //计数器值加1
        if (count[5:0]==6'b011111)
                bit_nb=1;
        else
                bit_nb=0;
end
assign seg=countPos;                                                        //输出数码管译码结果
endmodule
这是我写的一个相差90度的正交信号检测,用到滤波,计数
这个程序编译以后出现警告如下
Warning:Ignored unnecessary INPUT pin 'pha'
Warning:Ignored unnecessary INPUT pin 'phb'
编译也通过了,却居然将我的两个最主要的输入脚忽略了,请高手指点,错在何处
有没有高手可以帮个忙?
