各位大侠版主:
我用得是s12dg128b得片子,通过AD采集传感器得信号,程序如下:
#include <hidef.h> /* common defines and macros */ #include <mc9s12dg128.h> /* derivative information */
#pragma LINK_INFO DERIVATIVE "mc9s12dg128b" int i; unsigned char * ADPointer[8]; unsigned int Sen_Read_Result[8]; #pragma CODE_SEG DEFAULT
void AD_Init(void){
ATD0CTL2 = 0xc0; //寄存器自动清零 ATD0CTL3 = 0x00; //转换序列长度为8 ATD0CTL4 = 0x88; // 8bit AD时钟8/9 ATD0CTL5 = 0x30; //连续多通道转换,左对齐 ATD0DIEN = 0x00; //禁止数字输入
ADPointer[0] = &ATD0DR0H; ADPointer[1] = &ATD0DR1H; ADPointer[2] = &ATD0DR2H; ADPointer[3] = &ATD0DR3H; ADPointer[4] = &ATD0DR4H; ADPointer[5] = &ATD0DR5H; ADPointer[6] = &ATD0DR6H; ADPointer[7] = &ATD0DR7H; }
void main(void) { AD_Init(); EnableInterrupts; for(i=0; i<8 ; i++) { Sen_Read_Result = *ADPointer; } }
用codewarrior观察Sen_Read_Result得值,发现它是在无规律得变化着,小弟急等各位大侠得帮助! 谢谢了! |
