no sourse reference found ??
一个工程原先编译调试都没有问题的,现在给其中添加了一个函数,调测时点击"Start"后就提示no sourse reference found,请问这是由于什么引起的,我添加完函数后Make没有错误提示呀. |
是添加了一个函数,还是添加了一个文件?看一下路径对不对,是否生成调试信息。 |
只添加了一个函数
看一下路径对不对,是否生成调试信息,怎么看呢,我不太明白.谢谢. |
可以把整个project打包发至:strongchen_free@yahoo.com.cn。 |
文件比较大,而且和硬件有关,不能通过单纯的软件仿真来调测的。 |
你这个错误似乎与硬件无关。你可以逐步简化你的程序,将无关的部分依次剥离,最后就可以找到问题到底出在哪里。 |
YOu are using the CW Special Edition, and the SMAC code has a "SE" version which uses the SMAC code in library frm with no debug information. You should however be able to debug the example applications, eg RangeDemo and WireLessUART.
If you still see no code in the source window, check in the Project Settings dialog that the project is built to include debug information. Another way to check is to chck to see if there is a dot in the Debug column in the Project Explorer pane - the column has a little bug (insect) icon at the top. You can toggle on and off debug information that way |
宁静致远 淡泊明志
--------------By AC |
要看zhudongpo是不是用的SMAC程序了,如果是的话,应该就是楼上说的问题。 |
