请教ZIGBEE为什么不能下载
请教ZIGBEE为什么不能下载
我用的是TT-ZIGBEE-002,用的是BDM-MULTILINK下载,下载的程序是SMAC4.2中的Wireless Uart工程,然后我用debug的时候弹出ICD-Connection Manager窗口,在interface中我选了BDM Multilink ,port中我选了LPT1,但是连接不上,我不知道为什么,请大侠指点。
珍惜一切!
这个wireless uart的target debug有些不对,你先不要选择,cancel,进入debug界面,然后从菜单中选择component->set target->选择HCS08, P&E target interface
在PEDebug菜单选择HCS08GT60,选择in circuit debug就可以下载调试了。
你的BDM_MULTILINK是并口的吗?应该是USB的吧。
海纳百川  有容乃大
我用的BDM MULTILINK确实是并口的,这有关系吗?我手头没有USB的,那我应该怎么处理呢?一定要用USB的吗?
珍惜一切!
你好,我用的是CW V5.1,我debug的时候是先cancle,然后在component->set connection...->选择HCS08, P&E Multilink/Cyclone Pro,点ok之后,弹出ICD-Connection Manager窗口,在interface中我选了BDM Multilink ,port中我选了LPT1,还是连接不上,command显示为:
executing P&E_FCS.hwl
!OPEN Source 0 0 60 53
NO CONNECTION
!Source < attributes MARKS off
!OPEN Procedure 0 30 60 25
!Procedure < attributes VALUES on,TYPES off
!OPEN Data 0 55 60 23
!Data:1 < attributes SCOPE global,COMPLEMENT None,FORMAT Symb,MODE automatic,UPDATERATE 10,NAMEWIDTH 16
!OPEN Data 0 78 60 22
!Data:2 < attributes SCOPE local,COMPLEMENT None,FORMAT Symb,MODE automatic,UPDATERATE 10,NAMEWIDTH 16
!OPEN Assembly 60 0 40 20
!Assembly < attributes ADR off,CODE off,ABSADR on,SYMB off,TOPPC 0x18A7
!OPEN Register 60 20 40 20
!Register < attributes FORMAT AUTO,COMPLEMENT None
!OPEN Memory 60 40 40 35
!Memory < attributes FORMAT hex,COMPLEMENT None,WORD 1,ASC on,ADR on,MODE automatic,UPDATERATE 10,ADDRESS 0x0
!OPEN Command 60 75 40 25
!Command < attributes CACHESIZE 1000
!bckcolor WHITE
!font 'Courier New' 9 BLACK
!AUTOSIZE on
!ACTIVATE "Procedure" "Data:1" "Data:2" "Assembly" "Register" "Memory" "Command" "Source"
done P&E_FCS.hwl
Loading Target ...
Windows NT detected.
Device is 9S08GT60.
Mode is In-Circuit Debug.
IO registers loaded for MC9S08GT60 from D:\Program Files\cw5.1\prog\REG\MCU1006.REG
executing P&E_FCS.hwc
done P&E_FCS.hwc
No Link To Target
Loading Target ...
Could not contact P&E Hardware Interface. Check Power and Connections.
ACK - Error during SYNC.
Device is 9S08GT60.
No Link To Target
in>
另"PEDebug菜单选择HCS08GT60,选择in circuit debug",不知道在哪,没找到!
希望你指点,谢谢!
[此贴子已经被作者于2006-10-10 15:40:46编辑过]
珍惜一切!
看起来你的MULTILINK的连接有问题,不知是MULTILINK本身有问题还是其他什么问题。并口的MULTILINK似乎要用一个电源吧,你连了吗?
海纳百川  有容乃大
没有连电源,BDM上好像有一个口可以接东西,不知道是不是电源接口,但是我们老师说不用接.这个BDM头应该要驱动吗?我装的是USB的,我想会不会是这个问题呢?你有并口的驱动吗?有的话给我发一份行么?谢谢!cherish_001@126.com
珍惜一切!
并口的似乎不要什么驱动,但你可以到P&E的网站上搜索一下。另外,也可以接一下电源试试。
海纳百川  有容乃大
