9S08DZ60 CAN Demo code
CAN:
// Sample for Freescale EVB9S08DZ60
// This project has been written for CodeWarrior 5.0 for HC(S)08
// Copyright (c) 2006 SofTec Microsystems
// http://www.softecmicro.com/
#include "derivative.h" /* include peripheral declarations */
#include "mscan.h"
// MSCANInit
// MSCAN Peripheral Initialization
void MSCANInit(void)
  char sj,p;
  char t_seg1, t_seg2;
  if (!CANCTL0&0x01)
    // Active MSCAN initialization mode
    CANCTL0 =0x01;
  // Wait until the MSCAN is in initialization mode
  while (!CANCTL1&0x01)
  sj = (SJW-1)<<6;
  p = (BRP-1);
  // Configures SJW and Tq clock Baud Rate Prescaler
  CANBTR0 = (sj|p);
  t_seg1 = (TSEG1-1);
  t_seg2 = (TSEG2-1)<<4;
  // Configure Time Segment 1 and 2, and one Sample per bit
  CANBTR1 = (t_seg1 | t_seg2);
  // Disables all the Filters
  CANIDMR0 = 0xFF;
  CANIDMR1 = 0xFF;
  CANIDMR2 = 0xFF;
  CANIDMR3 = 0xFF;
  CANIDMR4 = 0xFF;
  CANIDMR5 = 0xFF;
  CANIDMR6 = 0xFF;
  CANIDMR7 = 0xFF;
  // Enable MSCAN and normal operation and select the oscillator clock as MSCAN clock source
  CANCTL1 = 0x80;
  // Active MSCAN Normal Operation
  CANCTL0 = 0x00;
  // Wait until the MSCAN operates normally
  while(CANCTL1&0x01)
  // Wait until MSCAN is synchronized to the CAN bus
  while(!(CANCTL0&0x10))
// MSCANSendMsg
// MSCAN Send Message Routine
Bool MSCANSendMsg(struct can_msg msg)
  unsigned char n_tx_buf, i;
  // Checks len validity
  if(msg.len > MAX_LEN)
    return(FALSE);
  // Checks synchronization to CAN bus
  if(!(CANCTL0&0x10))
    return(FALSE);
  n_tx_buf = 0;
  do
    // Looks for a free buffer
    CANTBSEL=CANTFLG;
    n_tx_buf=CANTBSEL;
  }while(!n_tx_buf);
  // Write Identifier
  CANTIDR0 = (unsigned char)(msg.id>>3);
  CANTIDR1 = (unsigned char)(msg.id<<5);
  if(msg.RTR)
    // RTR=Recessive
    CANTIDR1 |= 0x10;
  // Write Data Segment
  for(i = 0; i < msg.len; i++)
    *((&CANTDSR0)+i) = msg.data;
  // Write Data Length
  CANTDLR = msg.len;
  // Write Priority
  CANTTBPR = msg.prty;
  // Clear TXx Flag (buffer ready to transmission)
  CANTFLG = n_tx_buf;
  return(TRUE);
// MSCANGetMsg
// MSCAN Get Message Routine
Bool MSCANGetMsg(struct can_msg *msg)
  unsigned char i;
  // Checks for received messages
  if(!(CANRFLG&0x01))
    return(FALSE);
  // Checks if message has standard identifier
  if(CANRIDR1&0x08)
    // IDE = Recessive (Extended Mode)
    return(FALSE);
  // Reads message
  msg->id = (unsigned int)(CANRIDR0<<3) |
            (unsigned char)(CANRIDR1>>5);
  if(CANRIDR1&0x10)
    msg->RTR = TRUE;
  else
    msg->RTR = FALSE;
  // Read Data Length
  msg->len = CANRDLR;
  // Read Data Segment
  for(i = 0; i < msg->len; i++)
    msg->data = *((&CANRDSR0)+i);
  // Clear RXF flag (buffer ready to be read)
  CANRFLG = 0x01;
  return(TRUE);
// MSCANCheckRcvdMsg
// Verify if a new message is available in the Receiver Buffer Register
Bool MSCANCheckRcvdMsg(void)
  if(CANRFLG&0x01)
    return(TRUE);
  else return(FALSE);
请问一下,这个can程序在芯片外连MC33742的时候初始化不能通过,显示不能同步,这是为什么?我用的是DZ60的芯片~
