CW3.1连接时出现L1102:out of allocation space in segment ROM_C000 at address
![Rank: 2](images/default/star_level2.gif)
版主好!大家好!我在使用DG128时候,链接出现L1102:out of allocation space in segment ROM_C000 at address 0xFEFF 的错误,我程序到了48K以上时出现的,我试着加#pragma CODE_SEG OTHER_ROM ,但无效,可能位置加错了。请问如何解决呢? |
要和PRM文件配合。你在PRM文件里面设置OTHER_ROM的地址了吗? |
是这段吗?谢谢!
SEGMENTS
RAM = READ_WRITE 0x2000 TO 0x3FFF;
/* unbanked FLASH ROM */
ROM_4000 = READ_ONLY 0x4000 TO 0x7FFF;
ROM_C000 = READ_ONLY 0xC000 TO 0xFEFF;
/* banked FLASH ROM */
PAGE_38 = READ_ONLY 0x388000 TO 0x38BFFF;
PAGE_39 = READ_ONLY 0x398000 TO 0x39BFFF;
PAGE_3A = READ_ONLY 0x3A8000 TO 0x3ABFFF;
PAGE_3B = READ_ONLY 0x3B8000 TO 0x3BBFFF;
PAGE_3C = READ_ONLY 0x3C8000 TO 0x3CBFFF;
PAGE_3D = READ_ONLY 0x3D8000 TO 0x3DBFFF;
/* PAGE_3E = READ_ONLY 0x3E8000 TO 0x3EBFFF; not used: equivalent to ROM_4000 */
/* PAGE_3F = READ_ONLY 0x3F8000 TO 0x3FBFFF; not used: equivalent to ROM_C000 */
END
如何设置OTHER_ROM的地址,能给个例子吗?谢谢! |
你在建project时选择的是什么memory模式?是small模式吗?如果是,那在PRM文件中已经定义了OTHER_ROM的地址,如下:
/* This is a linker parameter file for the MC9S12DB128 */ NAMES END /* CodeWarrior will pass all the needed files to the linker by command line. But here you may add your own files too. */
SEGMENTS /* here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. */ RAM = READ_WRITE 0x0400 TO 0x1FFF; /* unbanked FLASH ROM */ ROM_4000 = READ_ONLY 0x4000 TO 0x7FFF; ROM_C000 = READ_ONLY 0xC000 TO 0xFEFF; /* banked FLASH ROM */ PAGE_38 = READ_ONLY 0x388000 TO 0x38BFFF; PAGE_39 = READ_ONLY 0x398000 TO 0x39BFFF; PAGE_3A = READ_ONLY 0x3A8000 TO 0x3ABFFF; PAGE_3B = READ_ONLY 0x3B8000 TO 0x3BBFFF; PAGE_3C = READ_ONLY 0x3C8000 TO 0x3CBFFF; PAGE_3D = READ_ONLY 0x3D8000 TO 0x3DBFFF; /* PAGE_3E = READ_ONLY 0x3E8000 TO 0x3EBFFF; not used: equivalent to ROM_4000 */ /* PAGE_3F = READ_ONLY 0x3F8000 TO 0x3FBFFF; not used: equivalent to ROM_C000 */ END
PLACEMENT /* here all predefined and user segments are placed into the SEGMENTS defined above. */ _PRESTART, /* Used in HIWARE format: jump to _Startup at the code start */ STARTUP, /* startup data structures */ ROM_VAR, /* constant variables */ STRINGS, /* string literals */ VIRTUAL_TABLE_SEGMENT, /* C++ virtual table segment */ //.ostext, /* OSEK */ DEFAULT_ROM, NON_BANKED, /* runtime routines which must not be banked */ COPY /* copy down information: how to initialize variables */ /* in case you want to use ROM_4000 here as well, make sure that all files (incl. library files) are compiled with the option: -OnB=b */ INTO ROM_C000/*, ROM_4000*/; OTHER_ROM INTO PAGE_38,PAGE_39,PAGE_3A,PAGE_3B,PAGE_3C,PAGE_3D;
//.stackstart, /* eventually used for OSEK kernel awareness: Main-Stack Start */ SSTACK, /* allocate stack first to avoid overwriting variables on overflow */ //.stackend, /* eventually used for OSEK kernel awareness: Main-Stack End */ DEFAULT_RAM INTO RAM; //.vectors INTO OSVECTORS; /* OSEK */ END
ENTRIES /* keep the following unreferenced variables */ /* OSEK: always allocate the vector table and all dependent objects */ //_vectab OsBuildNumber _OsOrtiStackStart _OsOrtiStart END
STACKSIZE 0x100
VECTOR 0 _Startup /* reset vector: this is the default entry point for a C/C++ application. */ //VECTOR 0 Entry /* reset vector: this is the default entry point for an Assembly application. */ //INIT Entry /* for assembly applications: that this is as well the initialization entry point */
[此贴子已经被strongchen于2006-12-5 16:24:51编辑过] |
我用的是bank模式呀,#pragma CODE_SEG OTHER_ROM 应该加在哪呢?谢谢! |
如果你用的是BANKED模式,那DEFAULT的地址应该是在分页地址中,不应该出现溢出的情形。把你的project发给我看看吧:strongchen_free@yahoo.com.cn。 |
我改了一下:
OTHER_ROM INTO PAGE_38,PAGE_39,PAGE_3A;
OTH2_ROM INTO PAGE_3B,PAGE_3C,PAGE_3D;
然后把一些字模、表格前加了 #pragma CONST_SEG OTH2_ROM,现在又通过了,不知以后还会不会有问题。谢谢! |
又改了一下:
DEFAULT_ROM INTO PAGE_38,PAGE_39,PAGE_3A,PAGE_3B,PAGE_3C,PAGE_3D;
OTH1_ROM INTO ROM_4000;
然后把一些字模、表格前加了 #pragma CONST_SEG OTH1_ROM,现在运行是正确的 |
