我是第一次接触freescale的片子,刚开始几次也是出现搂主的问题,后来点击debug后鼠标忙,很长时间无反应,感觉象死机了一样,等待很长的一段时间后显示:
Loading Target ...
Initializing STARTUP command file:
CMDFILE STARTUP ON ".\cmd\P&E_Multilink_CyclonePro_startup.cmd"
Initializing RESET command file:
CMDFILE RESET ON ".\cmd\P&E_Multilink_CyclonePro_reset.cmd"
Initializing PRELOAD command file:
CMDFILE PRELOAD ON ".\cmd\P&E_Multilink_CyclonePro_preload.cmd"
Initializing POSTLOAD command file:
CMDFILE POSTLOAD ON ".\cmd\P&E_Multilink_CyclonePro_postload.cmd"
Initializing VPPON command file:
CMDFILE VPPON ON ".\cmd\P&E_Multilink_CyclonePro_vppon.cmd"
Initializing VPPOFF command file:
CMDFILE VPPOFF ON ".\cmd\P&E_Multilink_CyclonePro_vppoff.cmd"
Initializing UNSECURE command file:
CMDFILE UNSECURE ON ".\cmd\P&E_Multilink_CyclonePro_erase_unsecure_hcs12.cmd"
close_port()
usb: open_port(1);
force_background_mode() => 0
read_status()
=> 0xff
write_control()
reset_cable()
check_cable_error() => 0
find_speed(0, 10, 0) => 0
find_speed(10, 20, 0) => 0
find_speed(20, 29, 0) => 0
find_speed(30, 38, 0) => 0
find_speed(40, 48, 0) => 0
find_speed(50, 57, 0) => 0
find_speed(60, 66, 0) => 0
find_speed(70, 76, 0) => 0
find_speed(80, 85, 0) => 0
find_speed(90, 94, 0) => 0
find_speed(100, 104, 0) => 0
find_speed(110, 113, 0) => 0
find_speed(120, 122, 0) => 0
find_speed(130, 132, 0) => 0
find_speed(140, 141, 0) => 0
find_speed(150, 150, 0) => 0
find_speed(160, 160, 0) => 0
find_speed(170, 170, 0) => 0
find_speed(181, 181, 0) => 0
find_speed(193, 193, 0) => 0
find_speed(205, 205, 0) => 0
find_speed(218, 218, 0) => 0
find_speed(232, 232, 0) => 0
find_speed(247, 247, 0) => 0
find_speed(263, 263, 0) => 0
find_speed(280, 280, 0) => 0
find_speed(298, 298, 0) => 0
find_speed(317, 317, 0) => 0
find_speed(338, 338, 0) => 0
find_speed(360, 360, 0) => 0
find_speed(384, 384, 0) => 0
find_speed(409, 409, 0) => 0
find_speed(436, 436, 0) => 0
find_speed(465, 465, 0) => 0
find_speed(496, 496, 0) => 0
find_speed(529, 529, 0) => 0
Error: The debugger is currently not able to run
due to loss of contact with hardware.
read_bd_byte(0xFF07)
=> 0xFF
BDM speed problem
in>
请问各位这是什么原因????
