微毫度十分个扩大飞机公婆 该用户已被删除
#if defined( F8W_NWK_PRESENT )
osal_timer_ISR_TIM1, // vector 8 TPM1 overflow
#else
Default_Dummy_ISR, // vector 8 TPM1 overflow
#endif /* F8W_NWK_PRESENT */
Default_Dummy_ISR, // vector 7 TPM1 channel 2
Default_Dummy_ISR, // vector 6 TPM1 channel 1
Default_Dummy_ISR, // vector 5 TPM1 channel 0
FLL_Lost_Lock_ISR, // vector 4 ICG (FLL lock of clock)
LowVoltageDetectISR, // vector 3 Low voltage detect
#else
Default_Dummy_ISR, // vector 3 Low voltage detect
#endif
AbelInterrupt, // vector 2 External IRQ (Abel interrupt)
Default_Dummy_ISR, // vector 1 Software interrupt (SWI)
// vector 0 Reset (Watchdog timer, Low voltage detect, external pin, illegal opcode)
其中AbelInterrupt, // vector 2 External IRQ (Abel interrupt)
这一句是什么意思? |
