SCI 中断发送问题???
SCI 中断发送问题???
使用MC9S12DP256 ,用中断方式发送一串 数据
“0xf5 0xdd,0x03,0x00,0x04,0xff,0xff,0xff,0xfc,0x72,0x73,0xf5”
用串口助手看,隔一段时间就会发现发的数据不是
有丢数据或数据错的现象,请问中断发送方式应该注意些 什么?
要仔细检查一下信号的波特率是否准,发送端和接收端的格式是否匹配。
海纳百川  有容乃大
#include /* common defines and macros */
#include /* derivative information */
#pragma LINK_INFO DERIVATIVE "mc9s12dp256b"
/* ERROR code and STATUS definitions */
#define ERROR_OK 1
#define ERROR_ERROR 0
#define START_CYCLE 1
#define WAIT_CYCLE 0
// 2007-3-13
/*Global variables*/
unsigned char SCIIniTx;
unsigned char SCIString[13]={0xF5,0xDD,0x03,0x00,0x23,0x04,0xFF,0xFF,0xFC,0x72,0x73,0xF5,0xa};
//unsigned char SCIString[12]={'B','C','D','E','F','G','H','I','J','K','L','\0'};
unsigned char *SCIStringp;
unsigned char Stringcase;
unsigned char * g_pSci1TxHead = SCIString;
unsigned char * g_pSci1TxBufEnd = SCIString + 11;
#pragma CODE_SEG __NEAR_SEG NON_BANKED
interrupt 20 void SCI0_rx(void)
if (SCI0SR1 & 0x80)
{ /*If transmission flag is set*/
SCI0SR1;
//if(*(SCIStringp++) != '\0')
if (g_pSci1TxHead != g_pSci1TxBufEnd)
//if(*SCIStringp > 0xD)
//{ /*Avoid to change CR and LF characters*/
// SCI0DRL=*SCIStringp + Stringcase;
//else{
g_pSci1TxHead++;
SCI0DRL= *SCIStringp++;;
else
SCIIniTx=START_CYCLE; /*Start new transmission cycle*/
SCI0CR2 &= 0x7F; /*Disable TDRE interrupt*/
if(SCI0SR1 & 0x20){ /*If reception flag is set*/
SCI0SR1;
if(SCI0DRL == 'U' || SCI0DRL == 'u'){
Stringcase = 0x00; /*Uppercase the character string*/
else if(SCI0DRL == 'L' || SCI0DRL == 'l'){
Stringcase = 0x20; /*Lowercase the character string*/
return;
#pragma CODE_SEG DEFAULT
// SCI参数设置
void Init_SCI(void)
//SCI0与Monitor通信
SCI0BDL=6;
SCI0BDH=0; //CLOCK=7.3728MHz, bps=38400
SCI0CR1=0x16; //9 bit, 偶效验
SCI0CR2=0x2C; //中止符产生器关闭
void SCITx(unsigned char SCIByte){
SCI0DRL = SCIByte; /*Write data byte to SCIDRL register*/
SCI0CR2 |= 0x80; /*Enable TDRE interrupt*/
void main(void)
/* put your own code here */
EnableInterrupts;
Init_SCI();
SCIIniTx = START_CYCLE; /*Initialize transmission cycle flag*/
for (;;)
if(SCIIniTx == START_CYCLE){
SCIIniTx = WAIT_CYCLE;
SCIStringp=SCIString; /*Set pointer to character string*/
SCITx(*SCIStringp + Stringcase);/*Send first byte of string*/
[此贴子已经被作者于2007-3-26 16:53:09编辑过]
上面代码是通过改动 AN2883SW.ZIP 。
发送数据时大部分时间是正确的,中间会出现错误数据帧。
使用是mc9s12dp256b ,PC端使用 串口调试助手V2.2.exe 接收数据。
麻烦Strongchen 给看看。谢谢了
这么一大段程序,还真不好办呢:))。要么你把整个PROJECT打包贴出来,我有空时试试吧。
海纳百川  有容乃大
http://bbs.eccn.com/uploadImages/SCI.rar
你的数据格式为什么要选9位而不是8位的?
海纳百川  有容乃大
[upload=image/pjpeg]uploadImages/SCI.JPG[/upload]
SCI0CR1=0x12; 9bit
SCI0CR1=0x02; 8bit 串口助手接收的数据根本就是错的。。
数据格式为什么要选9位而不是8位的?是因为 使用了偶校验
我试过多种组合了,还是有问题,请问strongchen 如果串口助手的设置如上图所示,
SCI0CR1 应该怎么设置呢,还是除了SCI0CR1 之外别的控制寄存器也需要进行设置,
急切等待您的答复,谢谢。
[此贴子已经被作者于2007-3-28 11:54:41编辑过]
我试过将波特率降低为9600,还是有问题。
请问各位有什么方法吗,谢谢了。
有没有用示波器看过波形?数据和脉冲宽度是否正确?
海纳百川  有容乃大
数据长度并不包括校验位。
海纳百川  有容乃大
我把程序稍微改了一下,你试试看(主要是对TDRE的操作)。
if (SCI0SR1 & 0x80)
SCI0SR1;
//else{
g_pSci1TxHead++;
else
/*SCI0CR2 &= 0x7F; /*Disable TDRE interrupt*/
SCI0SR1;
return;
// SCI²ÎÊýÉèÖÃ
void Init_SCI(void)
//SCI0ÓëMonitorͨÐÅ
////SCI0BDL=6;
SCI0BDL=13;
////SCI0CR1=0x16; //9 bit, żЧÑé
SCI0CR1=0x06; //8 bit, żЧÑé
SCI0CR2=0x2C; //ÖÐÖ¹·û²úÉúÆ÷¹Ø±Õ
/*SCI0CR2 |= 0x80; /*Enable TDRE interrupt*/
void main(void)
DDRB = 1;
while (1){
PORTB_BIT0^=1;
EnableInterrupts;
Init_SCI();
for (;;)
[此贴子已经被strongchen于2007-3-30 15:34:02编辑过]
海纳百川  有容乃大
strongchen 你好,你说数据长度并不包括校验位,SCI0CR1=0x06; //8 bit,
我已经试过了,收到数据是错误的,而SCI0CR1=0x16; //9 bit 收到数据才是正确的,
只是不停的发送过程中,我通过串口助手看到有一些错误的数据而已。用8bit 收到数据全错了。
[upload=image/pjpeg]uploadImages/SCI0.JPG[/upload]
