[求助]请大虾帮忙,我的9S12DG128MPV
我的9S12DG128MPV新做的试制板,第二块板仿真器能识别芯片,但是在COMMAND窗口看到的芯片总线速度为1.2MHZ,实际我使用的是16MHZ有源晶振,示波器测量频率很准!
请教各位这是什么原因?通过串口初始化的发送速度,也证明总线速度不为8MHZ.另芯片是用手工焊的,效果很差!下面是COMMAND中的相关信息:
Reset command file correctly executed.
FP: FLASH parameters loaded for MC9S12DG128B_V11(NVMIF2) from D:\Program Files\Freescale\CW for HC12 V4.5\prog\FPP\mcu03DC.fpp
MCU clock speed: 1297000 Hz
Block Module Name Address Range Status
0 EEPROM 2000 - 27FF Blank - Unselected
1 FLASH_4000 4000 - 7FFF Blank - Unselected
2 FLASH_C000 C000 - FFFF Programmed - Unselected
3 ALL_PPAGES 388000 -3FBFFF Programmed - Unselected
4 FLAT8000_P38 8000 - BFFF Programmed - Unselected
FP: The UNPROTECT command is not available for the EEPROM flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_4000 flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_C000 flash module => Skipped.
FP: The UNPROTECT command is not available for the ALL_PPAGES flash module => Skipped.
FP: The UNPROTECT command is not available for the FLAT8000_P38 flash module => Skipped.
executing .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
!// Before programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
Vppon command file correctly executed.
executing .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
!// After programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
Vppoff command file correctly executed.
FP: Arm FLASH for loading.
FP: FLASH disarmed.
executing .\cmd\P&E_Multilink_CyclonePro_reset.cmd
!// After reset the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_reset.cmd
executing .\cmd\P&E_Multilink_CyclonePro_postload.cmd
!// After load the commands written below will be executed
RESET
done .\cmd\P&E_Multilink_CyclonePro_postload.cmd
Postload command file correctly executed.
STARTED
RUNNING
Breakpoint
in>
附件为HI-WAVE中的COMMAND信息
救命啊!第一块板子焊完后仿真器(P&E)干脆无法烧写FLASH,不能识别芯片的通讯速度.
检查一下芯片其他引脚的信号是否正常。如XCLKS,MODA,MODB, MODC等。
海纳百川  有容乃大
我做的DG128的开发板,没任何问题的,可能你的管脚电平不对或者没有复位芯片[upload=image/pjpeg]uploadImages/DG128.jpg[/upload]
水泡泡
 我的QQ是:52449804
 我的网站是: www.dyic.com.cn
 欢迎访问和留言跟我联系
1。要有复位芯片
2。XCLK,Test等管脚电平要正确
3。芯片要没虚焊
水泡泡
 我的QQ是:52449804
 欢迎访问和留言跟我联系
很简单 你的晶振没有起振
可以把你的晶振电路贴出来看看吗?
使用有源晶振 XCLK=>GND!!!!!!!!!!
晶振问题,查看连接,MCU没有检测到外部晶振会自动使用内部时钟源,频率和你所说的值一致
精通S12,精通cw,有license 欢迎交流
onionchen1983hotmail.com
51,freescale,c,asm,protel,fpga
