如果在接受到一个数据包时测的A==MLMEEnergyDetect(),
B==MLMELinkQuality (),
A和B有什么异同??
即以下两个函数有何异同??
* PLMEEnergyDetect : Measure channel energy.
* Parameters : None
* Return : Energy
UINT8 PLMEEnergyDetect (void)
/* Note: Actual power returned is: -(power/2) */
/* Global calibration required for accuracy. */
UINT16 u16Reg;
UINT8 u8Power;
gu8RTxMode = CCA_MODE; /* Write energy detect mode */
u16Reg = SPIDrvRead(MODE_ADDR);
u16Reg &= 0xFFF8;
u16Reg |= CCA_MODE;
SPIDrvWrite(MODE_ADDR, u16Reg);
RTXENAssert();
while (gu8RTxMode != IDLE_MODE) /* Wait for energy detect to complete */
MCU_LOW_POWER_WHILE();
u16Reg = (SPIDrvRead(CCA_RESULT_ADDR) & 0xFF00);
u8Power = (u16Reg >> 8);
return u8Power;
* PLMELinkQuality : Report energy from last successful RX packet.
* Parameters : None
* Return : Energy
UINT8 PLMELinkQuality (void)
UINT16 u16Reg;
UINT8 u8Power;
u16Reg = SPIDrvRead(CCA_RESULT_ADDR);
u8Power = ((u16Reg & 0xFF00) >> 8);
return u8Power;
