往MD9S12DP256B内下载程序被提示:No programming voltage
往MD9S12DP256B内下载程序被提示:No programming voltage怎么回事?
具体情况:
MCU clock speed: 2797000 Hz
Block Module Name Address Range Status
0 EEPROM 400 - FFF Blank - Unselected
1 FLASH_4000 4000 - 7FFF Programmed - Unselected
2 FLASH_C000 C000 - FFFF Programmed - Unselected
3 ALL_PPAGES 308000 -3FBFFF Programmed - Unselected
4 FLAT8000_P30 8000 - BFFF Programmed - Unselected
FP: The UNPROTECT command is not available for the EEPROM flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_4000 flash module => Skipped.
FP: The UNPROTECT command is not available for the FLASH_C000 flash module => Skipped.
FP: The UNPROTECT command is not available for the ALL_PPAGES flash module => Skipped.
FP: The UNPROTECT command is not available for the FLAT8000_P30 flash module => Skipped.
executing .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
!// Before programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppon.cmd
Vppon command file correctly executed.
FP: No programming voltage
FP: ALL_PPAGES flash module is bad or protected.
executing .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
!// After programming the flash, the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
Vppoff command file correctly executed.
FP: Arm FLASH for loading.
FP: FLASH disarmed.
executing .\cmd\P&E_Multilink_CyclonePro_reset.cmd
!// After reset the commands written below will be executed
done .\cmd\P&E_Multilink_CyclonePro_reset.cmd
Reset command file correctly executed.
executing .\cmd\P&E_Multilink_CyclonePro_postload.cmd
!// After load the commands written below will be executed
RESET
done .\cmd\P&E_Multilink_CyclonePro_postload.cmd
Postload command file correctly executed.
main 0x308000 T
STARTED
RUNNING
ILLEGAL_BP
in>
其中在写程序前后分别执行了:
和done .\cmd\P&E_Multilink_CyclonePro_vppoff.cmd
我看了这两个工程所生成得文件,是空的,跟这有关系么?
请各位不吝赐教! |
[upload=image/bmp]uploadImages/下载界面.bmp[/upload]
这是下载界面! |
你可以用wizard引导建一个新的project,不做任何修改,然后用调试功能写芯片试试。 |
应该是编程电压的问题,我已经在板子上打开了使能位ROMON,可还是这样 |
那可能需要再仔细检查一下硬件了。或者用解密(unsecure)试试。 |
我也是初解除Freescale单片机。在Codewarrior中怎么看芯片处于加密状态? |
一般处于加密状态时就无法连接。不管是否加密,都可以unsecure试试。 |
我用Unsecure,却被告知:
derivative can not be unsecured!!!
The unsecured command file might be missing or disable.
Why? |
你用的是4.6版的CodeWarrior吗?重新下载安装一遍试试吧。 |
谢谢版主的帮助,问题解决了,在创建共产能够时,我用的时USB连BDM,而且用P&E Multilink_CyclonePro就出那问题,现在用Full Chip simulation就好了 |
P&E Multilink_CyclonePro和Full Chip simulation有什么区别?
我用的是USB接BDM,上面写着USB Multilink |
晕啊!还是那个问题,我被愚了!Full Chip simulation模式是脱离硬件的仿真,其实他没有硬件也可以调试程序。最终还是没有能下进去啊!!
郁闷!哪位能指点一下。怎么回事啊??? |
把你的整个project打包贴出来看看吧。或者发到strongchen_free@yahoo.com.cn。 |
您好,我只是用向导建了一个新工程,目的是调通板子。我把工程给您发邮箱去了,你帮我看看,怎么P&E_Multilink_CyclonePro_vppon.cmd和P&E_Multilink_CyclonePro_vppoff.cmd里面是空的?
