大家好:
本人第一次使用HC908JK8MCU
经过多方面的学习,现在程序终于可以运行起来。
显示,AD采集,数据处理都没有问题了!
但是,一个最重要的问题一只困扰着我。
我使用了定时器淤出中断,可程序就是进不了中断处理程序!
采用USB-MON08 Rev D 进行在线调试!
我的程序如下:
void InitTimer(void) //初始化定时器1---晶振频率=8MHZ,总线频率=2MHZ,分频因子=64,预置值=1250,=40毫秒一次中断
T1SC=0b01100110; //01100110允许溢出中断、
//不启动计数、分频因子=64
T1CNTH=0; //计数器初值清0
T1CNTL=0;
T1MODH=0x02; //设20毫秒产生1次溢出中断
T1MODL=0x71; //模数寄存器设定值
//中断频率:2000000/64*625 = 50Hz
T1SC_TOF=0;
#pragma CODE_SEG NON_BANKED
#pragma TRAP_PROC
//*定时器20Ms中断一次*/
interrupt void Timer_ISR(void)
T1SC_TOF=0;
SecData++;
//秒,分,时,开始计时
TimBuf[0]++;
if(TimBuf[0]>=60)
TimBuf[0]=0;
if(TimBuf[1]>=60)
TimBuf[1]=0;
if(TimBuf[2]>=24)
TimBuf[2]=0;
#pragma CODE_SEG DEFAULT
void main(void)
DisableInterrupts; /* 关中断 */
InitMcu();
InitDataCmd();
EnableInterrupts; /* 开中断 */
for(;;)
//KeyParse();//-------------键盘采集
LcdBuf[0]=0x01;
LcdBuf[1]=0x00;
LcdBuf[2]=0x00;//状态显示
LcdBuf[3]=0x00;
LcdBuf[4]=0xAa;//状态显示
LcdBuf[5]=0x08;//状态显示
AdParse();//--------------
FridgeStCon();//----------
LcdShowCmd();//-----------
//__RESET_WATCHDOG();//-----feeds the dog
另:
/* This is a linker parameter file for the JK8 */
NAMES END /* CodeWarrior will pass all the needed files to the linker by command line. But here you may add your own files too. */
SEGMENTS /* Here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. */
ROM = READ_ONLY 0xDC00 TO 0xFBFF;
Z_RAM = READ_WRITE 0x0060 TO 0x0090;
RAM = READ_WRITE 0x00a0 TO 0x015F;
END
PLACEMENT /* Here all predefined and user segments are placed into the SEGMENTS defined above. */
DEFAULT_RAM INTO RAM;
DEFAULT_ROM, ROM_VAR, STRINGS INTO ROM; /* In case you want to use as well, be sure the option -OnB=b is passed to the compiler. */
_DATA_ZEROPAGE, MY_ZEROPAGE INTO Z_RAM;
END
STACKSIZE 0x30
VECTOR 0 _Startup /* Reset vector: this is the default entry point for an application. */
VECTOR 2 IRQ1_ISR
VECTOR 6 Timer_ISR
另MAP中断分配:
VECTOR-ALLOCATION SECTION
Address InitValue InitFunction
0xFFF2 0xE7A4 Timer_ISR
0xFFFA 0xE78E IRQ1_ISR
0xFFFE 0xDC8C _Startup |
⌒╮\'╭⌒╮⌒╮.宠辱不惊,看庭前花开花落;;
︱田︱田田| ⌒╮去留无意,望天空云卷云舒;;
