看看这个问题!
看看这个问题!
interrupt 20 void sci0_isr(void) {
unsigned char p1 = 0x00;
unsigned char charnums = 0;
if(TDRE_0 == 1) {
p1 = SC0SR1;
SC0DRL = 0x55;
return;
interrupt 21 void sci1_isr(void) {
unsigned char p2 = 0x00;
if(RDRF_1 == 1) {
//PIB7 =0;
//delay(100);
p2 = SC1SR1;
szchar = SC1DRL;
if(szchar ==0x55) {
PE4 =1;
delay(500);
return;
void init_sci0(void) {
unsigned char readsc0sr =0x00;
SC0BDL = 0x1a; //baud rate :9600
SC0CR1 = 0x00; //8 bits
readsc0sr = SC0SR1; //clear Transmit flag
SC0DRL = 0x00;
SC0CR2 = 0xac; //interrupt close 0xac open
void init_sci1(void){
unsigned char writesc0sr =0x00;
SC1BDL = 0x1a;
SC1CR1 = 0x00;
SC1CR2 = 0xac;
writesc0sr = SC1SR1;
writesc0sr = SC1DRL;
上面代码会出现死循环,而且前两次收到的不是我发的0X55,从第三次才能收到。。。。为什么呢?
在哪里死循环?
海纳百川  有容乃大
就是在两个中断服务函数里面来回的跳,死循环我知道是什么问题了,我不明白为什么会前两次收不到正确的数据?
在两个中断服务函数之间来回地跳不算死循环。前两次收不到正确的数据可能是因为初时化后没有清中断标志。
海纳百川  有容乃大
