#include <hidef.h> /* common defines and macros */ #include <mc9s12dg128.h> /* derivative information */ #pragma LINK_INFO DERIVATIVE "mc9s12dg128b"
#include"sci.c"
void main(void) { /* put your own code here */ unsigned int AdValue;
DDRB=0XFF;
EnableInterrupts; ATD0CTL2=0X83; //Normal ATD functionality, //cause the associate CCF flag to clear automatically ATD0CTL3=0X04;//Conversion Sequence Length IS 8 BIT,Continue conversion ATD0CTL4=0X00; ATD0CTL5=0X00;//10-bit / left justified / unsigned - bits 6-15 //Single conversion sequence,Sample only one channel.AN0
SCI0Init();
while(ATD0STAT0_SCF) { AdValue=ATD0DR0;
WritedataToSCI0(AdValue,2); PORTB_BIT0!=PORTB_BIT0; ATD0CTL5=0X00;
以上是我写的程序,但是它没进入while条件判断语句,能指点一下吗,谢谢!
[此贴子已经被作者于2007-7-28 21:28:04编辑过] |
