请教版主
请教版主
请教版主, 在CW创建工程时如果忘记了选择 浮点运算支持,那么在工程建好后,如何修改编译器对浮点功能的支持。
先谢过了!
ALT+F7
在Compiler for HC12页
Command Line Arguments项宏:
-D__NO_FLOAT__ 表示不支持浮点运算
-Cf 表示Float IEEE32, doubles IEEE64
空 表示float and doubles are IEEE32
Project management window, “lib” folder, you could see one file called “ansisi.lib” or “ansibi.lib”,or "ansili.lib" please remove this lib from your project and import a new lib “ansisf.lib” or “ansibf.lib”or "ansilf.lib" to substitute it.
The method to import is: right click project management window, click “Add files…”, then in the opened select files window, go to {CW install folder}\lib\hc12c\lib to import right lib file.
最方便的方法是重建一个project,这应该很方便,再把源程序拷进新project即可。
海纳百川  有容乃大
