56F807dsp的cmd文件不知道怎么编,请大家帮忙
有例程也看不懂,也看了Targeting DSP56800.PDF文件,除了MEMORY懂外,SECTIONS部分还是不懂,请版主和大家帮帮忙吧 |
下面是编程环境自动生成的,看不太懂,所以也不知道该怎么根据自己的需要做改动
# linker command file for DSP56807EVM
# using
# external pRAM
# external xRAM
# internal xRAM (for compiler regs)
# mode 3
# EXT 0
# see end of file for additional notes
# additional reference: Motorola docs
# for this LCF:
# interrupt vectors --> external pRAM starting at zero
# program code --> external pRAM
# constants --> external xRAM
# dynamic data --> external xRAM
# stack size is set to 0x1000 for external RAM LCF
# requirements: Mode 3 and EX=0
# note -- there is a mode OB but any Reset or COP Reset
# resets the memory map back to Mode 0A.
# DSP56807EVM board settings
# ON --> jumper JG7 (mode 0 upon exit from reset)
# ON --> jumper JG8 (enable external board SRAM)
# CodeWarrior debugger Target option settings
# OFF --> "Use Hardware Breakpoints"
# ON --> "Debugger sets OMR at Launch" option
# note: with above option on, CW debugger sets OMR as
# OMR:
# 0 --> EX bit (stay in Debug processing state)
# 1 --> MA bit
# 1 --> MB bit
# 56807
# mode 3 (development)
# EX = 0
MEMORY
.p_interrupts_ext_RAM (RWX) : ORIGIN = 0x0000, LENGTH = 0x0080
.p_external_RAM (RWX) : ORIGIN = 0x0080, LENGTH = 0x0000
.x_compiler_regs_iRAM (RW) : ORIGIN = 0x0030, LENGTH = 0x0010
.x_internal_RAM (RW) : ORIGIN = 0x0040, LENGTH = 0x0FC0
.x_peripherals (RW) : ORIGIN = 0x1000, LENGTH = 0x0800
# .x_reserved : ORIGIN = 0x1800, LENGTH = 0x0800
.x_flash_ROM (R) : ORIGIN = 0x2000, LENGTH = 0x2000
.x_external_RAM (RW) : ORIGIN = 0x4000, LENGTH = 0xBF80
.x_core_regs (RW) : ORIGIN = 0xFF80, LENGTH = 0x0000
# we ensure the interrupt vector section is not deadstripped here
KEEP_SECTION{ interrupt_vectors.text }
# place all executing code & data in external memory
SECTIONS
.interrupt_vectors_for_p_ram :
# from 56807_vector_pROM.asm
* (interrupt_vectors.text)
} > .p_interrupts_ext_RAM
.executing_code :
# .text sections
* (.text)
* (rtlib.text)
* (fp_engine.text)
* (startup.text)
* (user.text)
} > .p_external_RAM
.data :
# .data sections
* (.const.data)
* (fp_state.data)
* (rtlib.data)
* (.data)
# .bss sections
* (rtlib.bss.lo)
__bss_start = .;
* (.bss)
__bss_end = .;
__bss_size = __bss_end - __bss_start;
# setup the heap address
__heap_addr = .;
__heap_size = 0x1000; # larger heap for hostIO
__heap_end = __heap_addr + __heap_size;
. = __heap_end;
# setup the stack address
_min_stack_size = 0x0200;
__stack_addr = __heap_end;
__stack_end = __stack_addr + _min_stack_size;
. = __stack_end;
# set global vars now
# MSL uses these globals:
F_heap_addr = __heap_addr;
F_heap_end = __heap_end;
F_stack_addr = __stack_addr;
# stationery init code globals
F_bss_size = __bss_size;
F_bss_addr = __bss_start;
# next not used in this LCF
# we define anyway so init code will link
# these can be removed with removal of rom-to-ram
# copy code in init file
F_data_size = 0x0000;
F_data_RAM_addr = 0x0000;
F_data_ROM_addr = 0x0000;
F_rom_to_ram = 0x0000; # zero is no rom-to-ram copy
} > .x_external_RAM
# additional notes:
# about the reserved sections
# for this external RAM only LCF:
# p_interrupts_RAM -- reserved in external pRAM
# memory space reserved for interrupt vectors
# interrupt vectors must start at address zero
# interrupt vector space size is 0x80
# x_compiler_regs_iRAM -- reserved in internal xRAM
# The compiler uses page 0 address locations 0x30-0x40
# as register variables. See the Target manual for more info.
# notes:
# program memory (p memory)
# (RWX) read/write/execute for pRAM
# (RX) read/execute for flashed pROM
# data memory (X memory)
# (RW) read/write for xRAM
# (R) read for data flashed xROM
# LENGTH = next start address - previous
# LENGTH = 0x0000 means use all remaing memory
# revision history
# 011020 R4.1 a.h. first version
# 030220 R5.1 a.h. improved comments
